There seems to be an issue controlling outputs via scripts. Jon told me to use hs.setdevicestatus deviceid,2 to turn on. Yet it never does in the latest release. I believe it was working in a prior release though.
Any ideas?
Any ideas?
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
Function ControlOutput(ByVal strOutput As String,
ByVal strAction As String,
ByVal strOnTime As String) As String
Sub Main(parm as object)
Dim strResults as String = ""
strResults = hs.plugin("UltraM1G").ControlOutput("016", "Off", "0")
If strResults.Length > 0 then
Call hs.WriteLog("Error", strResults)
End If
End Sub
End If
End Sub
