Thanks Ultra for you contributions. I'm installing an Elk shortly as the client loves the look of their flush mount keypads. Don't plan on using any of automation functions as HS will be handling 100% of these aspects.
The Elk M1 hardware and flush mount keypads will be replacing an already install DSC system. No sensor or wiring changes and no wireless at this stage.
Questions:
Interestingly for the first time I have read no stability issues with this security plugin. If so...kudos to you. So...is this plugin totally stable?
I will have the option of serial OR ethernet. Which is preffered? Any benefit to either? Which is the default method to minimize custom configuration
Key features for my client are: HS calls their cell phone when alarm breach, phone house and arm security or get security status, remote access via Web (I saw this on your demo). So...no issues on any of the above? All confirmed 100% operational in real world?
What thermostats are you all using with this plugin? Any zone limit numbers?
Has anyone built a MainLobby scene for this plugin yet?
Best place to buy the Elk MI and what hardware components or Elk M1 package required? SmartHome seems pretty limited in their stock on the flush mount keypads.
Thanks Ultrajones for your contributions.
Questions:
