Elk Plugin Errors
    Elk Plugin Errors
    It was working and now this, also the output toggles do not work any more.
    6/18/2007 3:56:33 PM - Info - Finished initializing plug-in UltraM1G
    6/18/2007 3:56:33 PM - UltraM1G Info - Download of current state information complete.
    6/18/2007 3:56:31 PM - UltraM1G Error - Data that caused error in ProcessCommand() subroutine: Len=1C, Cmd=LD, Data=1004403114480618007207, Reserved=00
    6/18/2007 3:56:31 PM - UltraM1G Error - An unexpected error occured in the ProcessCommand() function/subroutine: [System.NullReferenceException: Object variable or With block variable not set. at Microsoft.VisualBasic.CompilerServices.Symbols.Container..ct or(Object Instance) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.Intern alLateIndexGet(Object Instance, Object[] Arguments, String[] ArgumentNames, Boolean ReportErrors, ResolutionFailure& Failure) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateIn dexGet(Object Instance, Object[] Arguments, String[] ArgumentNames) at HSPI_ULTRAM1G.HSPI_M1G.GetFriendlyEventString(String EventCode, String EventNum, String Area, DateTime EventDT) at HSPI_ULTRAM1G.HSPI_M1G.ProcessCommand(String strLen, String strCmd, String strData, String strReserved)]
    6/18/2007 3:56:31 PM - UltraM1G Error - Data that caused error in ProcessCommand() subroutine: Len=1C, Cmd=LD, Data=1004403114480618009207, Reserved=00
    6/18/2007 3:56:29 PM - UltraM1G Info - Waiting for current state information to be downloaded from the M1 ...
    6/18/2007 3:56:03 PM - UltraM1G Info - Initial communication with Elk M1 was successful.
    Please help
    Mark
    <!-- / message -->
    Did you recently clear all the logs from your Elk M1? I thought I fixed this, will take a look again.
      In the log data you provided, the "UltraM1G Error" isn't really an error. The plug-in has a built in mechanism to ensure commands sent to the Elk M1 are processed. In this case, the Elk M1 sent log data, but the plug-in didn't have any outstanding log data requests.
      What version of the Elk M1 plug-in are you using?
      Are you using the Elk M1XEP?
      Ultrajones
        Plug-In Status Status: OK
        Version: 1.1.2688
        M1G Panel Status Connection Status: Connected
        Commands In Queue: 0
        Last Receive Event: 6/20/2007 12:15:43 AM
        M1G Logs Log Count: 20
        Supported Elk M1 Configuration Areas: 8 [1 defined]
        Keypads: 16 [1 defined]
        Users: 202 [3 defined]
        Zones: 208 [16 defined]
        Outputs: 208 [16 defined]
        Thermostats: 16 [0 defined]
        Custom Settings: 20 [0 defined]
        Tasks: 32 [0 defined]
        Lighting:
        Yes I am using the ethernet interface.
          What version of HomeSeer are you running?
            2.2.0.11
              I can't duplicate this issue on my production or development HS instance.
              Are you only getting this error on startup? Are you still seeing the error?
