Warning Messages
    Warning Messages
    Would appreciate any info. on the following warning messages in the log:
    3/22/2008 3:31:01 PM UltraM1G Info Zone 003 [East Out Motion] is Normal
    3/22/2008 3:34:12 PM UltraM1G Warning Invalid checksum 235 for command SS as data 0000000000000010000000000000000100
    3/22/2008 3:34:12 PM UltraM1G Warning Raw data was: 28SS00000000000000100000000000000001000019
    3/22/2008 3:36:39 PM UltraM1G Info Zone 002 [Garage Door] is Violated
    3/22/2008 3:38:04 PM UltraM1G Info Zone 002 [Garage Door] is Normal
    3/22/2008 3:38:17 PM UltraM1G Warning Invalid checksum 227 for command SS as data 0000000000000000000000000000000100
    3/22/2008 3:38:17 PM UltraM1G Warning Raw data was: 28SS00000000000000000000000000000001000012
    Thanks for any help...
    This error is caused by a bug in the latest Elk M1G firmware. I bought this to Elk's attention over 3 months ago. They have fixed the issue, but have not yet released the firmware.
    Ultrajones
      Ultra..
      Thanks for responding so quickly. This is a great plug-in.
      I did find a different type of warning message also in the log this morning, the 'Received unsupported SetIO action' ones. Are these also the result of an M1 firmware bug?
      Thanks again for the support...
      3/22/2008 11:52:40 PM UltraM1G Warning Received unsupported SetIO action for Elk M1 Lighting of type 4
      3/22/2008 11:52:46 PM UltraM1G Warning Received unsupported SetIO action for Elk M1 Lighting of type 4
      3/22/2008 11:59:58 PM System Switching to a new log file.
      3/23/2008 3:03:25 AM UltraM1G Warning Received unsupported SetIO action for Elk M1 Lighting of type 4
      3/23/2008 6:20:34 AM UltraM1G Warning Invalid checksum 235 for command SS as data 0000000000000010000000000000000100
      3/23/2008 6:20:34 AM UltraM1G Warning Raw data was: 28SS00000000000000100000000000000001000019
      3/23/2008 6:20:47 AM UltraM1G Warning Invalid checksum 242 for command SS as data 0000000000000000000000000000000100
      3/23/2008 6:20:47 AM UltraM1G Warning Raw data was: 28SS00000000000000000000000000000001000021
      3/23/2008 6:21:49 AM UltraM1G Warning Received unsupported SetIO action for Elk M1 Lighting of type 4
      3/23/2008 6:31:15 AM UltraM1G Warning Invalid checksum 235 for command SS as data 0000000000000010000000000000000100
      3/23/2008 6:31:15 AM UltraM1G Warning Raw data was: 28SS00000000000000100000000000000001000019
      3/23/2008 6:31:53 AM UltraM1G Warning Invalid checksum 16 for command SS as data 0000000000000000000000000000000100
      3/23/2008 6:31:53 AM UltraM1G Warning Raw data was: 28SS0000000000000000000000000000000100003F
      3/23/2008 6:32:55 AM UltraM1G Warning Received unsupported SetIO action for Elk M1 Lighting of type 4
      3/23/2008 6:33:00 AM UltraM1G Warning Received unsupported SetIO action for Elk M1 Lighting of type 4
        It appears your Elk system is reporting a lighting dim action, and the plug-in is rejecting it because the lighting dim action is not supported yet. I plan on adding diming support in the next few week.
        Ultrajones
          Ah, that explains a lot. I had been wondering why the Status page only provided an on/off action and no "dim to xx%" selection. Will keep an eye out for the update with dim capability...
          Once again, thanks for the help...
            Im seeing something similar. Any ideas here?
            config…
            Plug-In Status
            Status: OK
            Version: 3.0.6922.16073
            Elk M1 Panel Status
            Connection Status: Connected
            M1 Firmware: 5.2.4
            M1XEP Firmware: Unknown
            Commands In Queue: 0
            Last Receive Event: 2/13/2022 8:05:01 AM
            Elk M1 Log Count
            Log Count: 20
            Elk M1 Configuration Status
            Areas: 8 [1 defined]
            Keypads: 16 [2 defined]
            Users: 199 [3 defined]
            Zones: 208 [64 defined]
            Outputs: 208 [16 defined]
            Thermostats: 16 [3 defined]
            CustomSettings: 20 [1 defined]
            Counters: 64 [1 defined]
            Tasks: 32 [1 defined]
            Lighting: 256 [1 defined]
            AudioZones: 18 [1 defined]
            logs…
            2/13/2022 8:01:38 AM
            UltraM1G3
            Warning
            No response/improper response from Elk M1 to command 'a2100040600'
            2/13/2022 8:01:37 AM
            UltraM1G3
            Warning
            Raw data was: 1EAS00000000111111110000000000F9
            UltraM1G3
            Warning
            Invalid checksum 235 for command AS as data 000000001111111100000000
            2/13/2022 8:01:36 AM
            UltraM1G3
            Warning
            2/13/2022 8:01:35 AM
            UltraM1G3
            Warning
            UltraM1G3
            Warning
            2/13/2022 8:01:34 AM
            UltraM1G3
            Warning
            HomeSeer
            email
            Email successfully sent to [email removed]
            2/13/2022 8:01:33 AM
            UltraM1G3
            Warning
            UltraM1G3
            Warning
            2/13/2022 8:01:32 AM
            HomeSeer
            Event
            Event Trigger "ELK M1 Stay Mode"
