I just purchased the plugin and the setup was quite easy, no problem. I created a few events to email me when "Zone Status" = "Violated", and it worked fine. The only issue I have is the HS Status - Last Changed does not reflect the time of the event.
My log entries are:
3/26/2008 4:32:35 PM Info Event Trigger "Elk Back Door"
3/26/2008 4:32:36 PM Info Email successfully sent to xxxx.com
Device status is:
Secure ELK-M1 Back Door #20 Burglar Zone 18 Today 7:14:16 AM
The status times are from this morning.
I also had the free plugin runnig then. - Do I need to delete all of the defvices and startover? When I removed the other plugin the devices went with it. Installing this one created new devices. I am using the latest firmware which supports the GE Caddx 548 interface.
Any suggestions?
Skybolt
update: The Zone status screen is coorect:
017 1 Side Door Burglar Entry/Exit 1 Normal [EOL] Not In Alarm 3/26/2008 4:38:41 PM
but not updated in the HS status devices
My log entries are:
Device status is:
Any suggestions?
Skybolt
