Ultra, need your help again..
The highlighted error message occurs everytime HS starts up. At first it would appear occassionally at startup, now it appears every time HS starts up.
3/27/2008 9:01:22 PM UltraM1G Info UltraM1G version 1.1.2934.36888 starting ...
3/27/2008 9:01:22 PM Info Initializing Plug-in: UltraM1G
3/27/2008 9:01:22 PM UltraM1G Info UltraM1G - initializing I/O ...
3/27/2008 9:01:22 PM UltraM1G Info Attemping initial communication with Elk M1 ...
3/27/2008 9:01:22 PM UltraM1G Info Updating ELK M1 internal real-time clock to 3/27/2008 9:01:22 PM
3/27/2008 9:01:22 PM UltraM1G Info Elk Real Time Clock reports: 03/27/2008 21:01:22, mm/dd format, 12 hour format, DST is Active
3/27/2008 9:01:22 PM UltraM1G Info Initial communication with Elk M1 was successful.
3/27/2008 9:01:26 PM UltraM1G Info Waiting for current state information to be downloaded from the M1 ...
3/27/2008 9:01:27 PM UltraM1G Warning The following Elk M1 System troubles have been reported: Display Message In Keypad Line 1
3/27/2008 9:01:27 PM UltraM1G Error An unexpected error occured in the ProcessCommand() function/subroutine: [System.InvalidCastException: Conversion from string "O" to type 'Integer' is not valid. ---> System.FormatException: Input string was not in a correct format. at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDoub le(String Value, NumberFormatInfo NumberFormat) at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger (String Value) --- End of inner exception stack trace --- at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger (String Value) at HSPI_ULTRAM1G.HSPI_M1G.ProcessCommand(String strLen, String strCmd, String strData, String strReserved)]
3/27/2008 9:01:27 PM UltraM1G Error Data that caused error in ProcessCommand() subroutine: Len=47, Cmd=PS, Data=000000000000000000000000000000O000000000`00000000000000 0000000000, Reserved=00
3/27/2008 9:01:27 PM UltraM1G Info Download of current state information complete.
3/27/2008 9:01:27 PM Info Finished initializing plug-in UltraM1G
As usual, thanks for your assistance...
