No Response to az00
  • No Response to az00
    Just installed the M1 plugin and was able to get everything hooked up. I did notice some odd errors occuring;
    8/8/2009 6:02:16 PM - UltraM1G Info - Zone 001 [GarageEntryDoor] is Violated
    8/8/2009 6:02:18 PM - UltraM1G Warning - No response/improper response from Elk M1 to command 'az00'
    8/8/2009 6:02:19 PM - UltraM1G Warning - No response/improper response from Elk M1 to command 'az00'
    8/8/2009 6:02:19 PM - UltraM1G Info - Zone 001 [GarageEntryDoor] is Normal
    8/8/2009 6:02:21 PM - UltraM1G Info - Zone 008 [Garage1-Door] is Violated
    8/8/2009 6:02:21 PM - UltraM1G Warning - No response/improper response from Elk M1 to command 'az00'
    8/8/2009 6:03:12 PM - UltraM1G Info - Zone 001 [GarageEntryDoor] is Violated
    8/8/2009 6:03:14 PM - UltraM1G Warning - No response/improper response from Elk M1 to command 'az00'
    8/8/2009 6:03:16 PM - UltraM1G Warning - No response/improper response from Elk M1 to command 'az00'
    8/8/2009 6:03:17 PM - UltraM1G Warning - No response/improper response from Elk M1 to command 'az00'
    I was wondering what they are and what to do about them.
    thanks.
    What firmware version are you running on your Elk M1?
      I am running V4.3.8
        Hello sforeman00. The firmware version 4.3.8 does not support the az command. The firmware version you are running was released on Oct 26, 2005. It is at least 12 versions behind the latest (4.5.20). Have you considered upgrading it?
        Ultrajones
          I didn't realize I was so far behind so after your question I downloaded the latest version that supports the caddx V4.5.20.
          Hopefully no problems with that version?
            Correct.
              Upgraded to 4.5.20 and it now works.
              thanks.
                az00 Error
                I am as well having this error in the log. I am running ELK M1 Firmware 5.3.0 and Plugin version 3.0.5437.37424. Any suggestions to end this error?
                Cheers
                  Hi,
                  I'm seeing the same issues running 5.3.10 and plugin version 3.0.6225.23941
                  Feb-15 4:16:25 PM Warning No response/improper response from Elk M1 to command 'az00'
                  Feb-15 4:16:24 PM Warning Raw data was: DAAZ00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000008B
                  Feb-15 4:16:24 PM Warning Invalid checksum 11 for command AZ as data 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000
                  Any helping in sorting this error would be great.
                  -Philip
                    I'm getting the same issue. plugin version 3.0.6267.36391 Firmware 5.3.10.
                    Originally was on an older firmware and events tied to zone changes were really delayed. looked in the logs and noticed I was getting the "Warning No response/improper response from Elk M1 to command 'az00'" error in the log. Did a quick search and it was suggested to upgrade to the latest firmware. Now that I'm on 5.3.10 I still have the same error in the log and the same delayed event actions.
                    Mar-19 11:41:12 PM Warning No response/improper response from Elk M1 to command 'az00'
                    Mar-19 11:41:10 PM Warning No response/improper response from Elk M1 to command 'az00'
                    Mar-19 11:41:08 PM Warning No response/improper response from Elk M1 to command 'az00'
                    Mar-19 11:41:02 PM Warning No response/improper response from Elk M1 to command 'az00'
                    Mar-19 11:41:00 PM Warning No response/improper response from Elk M1 to command 'az00'
                    Mar-19 11:40:58 PM Warning No response/improper response from Elk M1 to command 'az00'
                    anyone find a resolution? Ultrajones Help!!!
                      Is this causing any problems? I think that I have received these errors for a long time and can not determine if there ever were any negative impacts.
                      If I recall correctly, then I have looked this command up within the ELK manual and determined at that time that it is a undocumented command.
                      Somehow I came to think that this is not a major issue.
                        I had never seen these errors before but now I walk into the kitchen and it takes 15min+ for HS to see there is motion and turn the lights on. Seems too much of a coincidence.
                          I'm getting the same errors as the others above.
                          Elk M1G firmware: 5.3.10
                          M1XEP firmware: 2.0.42
                          Plugin: 3.0.6267.36391
                          Apr-16 01:20:10 Warning No response/improper response from Elk M1 to command 'az00'
                          Apr-15 23:38:12 Warning No response/improper response from Elk M1 to command 'az00'
                          Apr-15 23:34:03 Warning No response/improper response from Elk M1 to command 'az00'
                          Apr-15 20:37:39 Warning Raw data was: 0AC042900C3
                          Apr-15 20:37:39 Warning Invalid checksum 166 for command C0 as data 429
                          Apr-15 20:36:40 Warning No response/improper response from Elk M1 to command 'az00'
                          Apr-15 20:36:39 Warning Invalid checksum 208 for command AZ as data 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000
                          Apr-15 20:36:39 Warning Raw data was: D6AZ00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000008B
                          iCore5 Win 10 Pro x64 SSD
                          HS3 Pro Edition 3.0.0.435 Windows
                          BLOccupied:,Device History:,Yamaha:,UltraMon3:,mcsXap:,Restart:,UltraNetatmo3:, UltraM1G3:,Ultra1Wire3:,BLBackup:,Harmony Hub:,DoorBird:,UltraECM3:,Nanoleaf 3P:,UltraRachio3:,Z-Wave:,SDJ-Health:,BLGarbage:,Blue-Iris:,Chromecast:,Pushover 3P:,EasyTrigger:
                            Most of the communication between the UltraM1G3 HSPI and the Elk M1 panel is event driven meaning the Elk M1 will send changes as they occur to the plug-in. However, the az00 query is an exception. It's one of the few things that need to be queried via polling. The poll mechanism sends the command to the Elk M1 and waits for the response. If no response is received within 1.5 seconds (default value), then the command is retried 1 more time (default value). Anytime a command sent to the Elk M1 does not produce the expected response, a warning is written to the HomeSeer logs. This is why you could see this particular command time-out on occasion.
                            If you are seeing a time-out error in your log more than a few times per day, then it's an issue needing to be investigated. In my experience, the cause for this timeout is:
                            • Network packet loss between HomeSeer and the Elk M1 XEP.
                            • Bad serial cable between Elk M1 and Elk M1 XEP.
                            • Bad network cable.
                            To test packet loss from HomeSeer to the Elk M1 XEP, then simply connect to your HomeSeer system and run the command:
                            ping -n 1000
                            The results of this command should show 0% packet loss.
                            Ultrajones
                              So I pinged the M1XEP from my HS machine. The results were 100% packet transmission (no loss) with an average time of 0ms, 999 were less than 1ms, one was 12ms.
                              It seems the network side is working perfectly. The setup has been untouched for a couple of years. Only the firmware and plugin have changed over this period.
                              I do have have Elk C-bus interface (Rev 3) connected. I wonder if other people seeing this error have any lighting interfaces connected.
                              M
