OS: Windows 2k
Service: No
AV: Yes, Symantec, but tested disabled
Elk Firmware: 4.5.20
HS Pro: 2.4.0.3
The attached logs show communication errors with the Elk panel. Debug log has been sent.
I thought it was some type of serial communication error. I increased the "Wait time per command" to 3.5 and also decreased the serial port on the M1 to 9600 baud, but that doesn't seem to have helped at all.
RP works fine - I just used it to update all firmware's on the Elk in troubleshooting this issue.
Any help anyone could give would be GREATLY appreciated. I'm trying to replace the my.elk script with this much more powerful plugin.
Thanks!
-Chak
Service: No
HS Pro: 2.4.0.3
Thanks!
-Chak
12/6/2009 9:25:47 PM UltraM1G Warning Watchdog Timer reconnect attempt failed :Could not communicate with ELK M1 System! 12/6/2009 9:25:47 PM UltraM1G Info Could not communicate with Elk M1 ... 12/6/2009 9:25:44 PM UltraM1G Info Updating ELK M1 internal real-time clock to 12/6/2009 9:25:44 PM 12/6/2009 9:25:41 PM UltraM1G Info Updating ELK M1 internal real-time clock to 12/6/2009 9:25:41 PM 12/6/2009 9:25:38 PM UltraM1G Info Updating ELK M1 internal real-time clock to 12/6/2009 9:25:38 PM 12/6/2009 9:25:38 PM UltraM1G Info Attemping initial communication with Elk M1 ... 12/6/2009 9:25:38 PM UltraM1G Info Running version has changed, forcing full data download from Elk M1 System ... 12/6/2009 9:25:38 PM UltraM1G Info UltraM1G - initializing I/O ... 12/6/2009 9:25:38 PM UltraM1G Error An unexpected error occured in the SaveM1DataToINI function/subroutine: [System.NullReferenceException: Object variable or With block variable not set. at Microsoft.VisualBasic.CompilerServices.Symbols.Container..ctor(Object Instance) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.InternalLateIndexGet(Object Instance, Object[] Arguments, String[] ArgumentNames, Boolean ReportErrors, ResolutionFailure& Failure) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateIndexGet(Object Instance, Object[] Arguments, String[] ArgumentNames) at HSPI_ULTRAM1G.HSPI_M1G.SaveM1DataToINI()] 12/6/2009 9:25:38 PM UltraM1G Info UltraM1G - shutting down I/O ...
