Plugin exposes ELk T-stats into HS T-stats?
    Does this plugin support the t-stat api's in HomeSeer? In other words, if I have three t-stats hooked up to the ELK via this plugin, should I be able to see these t-stats as HS t-stats in HSTouch?
    If not, then this would be a nice add-on.
    I was just trying to do this the other day… I found that the templates provided by HSTouch used “Thermostat: Raise or Lower the Heat Setpoint”, but I couldn’t find any info on it. I checked the docs and couldn’t find anything. Do you happen to have a link to it?
    Ultrajones
      We'll glad to help.
      Here are my thoughts - but I presume that you know most of this already:
      Does the plugin currently support the HS t-stat API? If not, then I presume that you will need to code the plugin to interface to the HS t-stat API. Once that is completed, then HSTouch should recognize the t-stats that the ELK has connected.
      Dropping the tstat template in HSTouch should then allow it to all function.
      I have three t-stats, so support of more than one would be appreciated.
        Best I can tell, the t-stat API is just a call to an underlying scripts.
          Wow, I wish I knew the thermostat API existed. I added all the functions assoicated with the thermostat API to the UltraM1G plug-in. I then dropped in an HAI thermosat in an HSTouch project, selected the thermosat and it "just worked". Very cool.
            Good, sounds like my babble may have helped. Cool. Ill test it over the weekend. Rich may send me the latest IPAD code for testing...
              I just finished adding support for the HomeSeer thermostat API. It should support up to 16 thermostats connected to the Elk M1. Please download UltraM1G HSPI version 1.1.4031.24574 to try it out.
              Ultrajones
                Seems to work... Awesome! Thanks!
                  same here. works ok for me. thanks!
