Compatibility with Hometroller SE
    I am considering replacing my HS PC with a Hometroller SE.
    Is the UltraM1G plugin for the Elk system compatible?
    Tom
    Yes it is. The HomeTroller will work with all HomeSeer plugins. The MCSprinklers plugin is the only one that I know of that takes a bit of work to get it working.
      Tom
      Hello Tom. I just picked up a Hometroller SE. I plan on running a few tests to confirm full compatibility with the UltraM1G HSPI.
      Ultrajones
        Elk M1 Plug-in problem.
        Ultra,
        I installed your plugin on the Hometroller-SE. Everything was working fine until tonight. I re-started HS after installing another plug-in (Global Cache). I received the following message in the log:
        "A new base IO code of '`' for class 'NonThermostat' was issued by HomeSeer."
        The device for the Ethernet connection was changed BUT the HS device for the area was GONE. This caused major problems with my HSTouch screens that arm the alarm and track this device.
        I don't think this is due to the Hometroller-SE but I would like to understand what happened. Any idea's
        Tom
          Hello Tom. There is one section of code that could delete devices assoicated with the plug-in. This is a section of code that "should never happen". Please check your logs to see if the following string was written:
          "Unable to obtain base code; Try restaring HomeSeer."
          Note: Yes, I noticed the typo in the error message above
          Ultrajones
            No I don't think this appeared in my log.
            Tom
