I currently have a rule that Arm in stay mode with one of my door bypassed.
When in this mode I want to turn on my lights when the bypassed door is opened (Violated).
This does not work because the system seem to totally ignore whatever happens on that zone since it is bypassed. I guess a bypassed zone can't be violated, and that makes sense.
I have seen the same issue with the Elk module for ISY. However that plugin provides 3 different informations to use as trigger/conditions : Physical Status (Open, Short, EOL), Status (Normal, Trouble, Violated, Bypassed) and Voltage. I was able to make this work in ISY by using the physical status.
Is there a way to get the physical status information to use as triggers/conditions in UltraM1G?
