my elk m1g is fed thru a ups... when the house power fails, there is no way to tell we are on backup... how do i utilize the "power fail" alert ability? do i need an external relay that is fed from a normal house outlet to connect to an elk digital output?
power fail alert
try this one...
http://www.smarthome.com/7154/Winland-Electronics-PS-110-Power-Out-Sensor/p.aspx
seems simple enough then tie to a contact in your elk to create a device and then a HS event when it gets tripped.
should work??HS3 , Zwave, HometrollerS6, ELK M1G Ultra; mcs sprinklers; WGL800; BLRF; BLNetCallerID; BLSpeech
