Connection issues
    Connection issues
    Hey guys,
    Need some help ! Over the last few weeks, the plugin is not able to connect to the panel.
    It keeps throwing the below message at startup -
    /8/2013 11:31:17 PM Error Initializing interface: UltraM1G-Unable to initialize Elk M1 Hardware :Unable to connect to 192.168.1.28
    I'm running homeseer on windows 7 ultimate with the latest update applied to homeseer and is connected via network to the m1 xep module . The only other plugin running is the sonos plugin.
    The plugin has been running fine since the initial install in 2012 but something broke in the last couple months and am not sure what
    I've tried reinstalling Homeseer, un-installed and re installed the ultra plugin, updated HS via the update package from the HS website, changed DNS server s on the router (read somewhere that was causing issues).
    Any other ideas ?
    Thanks in advance
    What Operating System Are You Using: (XP/Vista/7)
    7
    Are you running HomeSeer as a service? (Yes/No)
    No
    How is HomeSeer connected to the Elk M1? (serial/M1XEP):
    m1xep
    Do you run any anti-virus programs? If Yes, indicate the name and version.
    yes, AVG
    Describe the issue you are experiencing.
    Plugin will not connect to the panel. Message shown in the log says target machine actively refused connection.
    Are you able to duplicate the issue? (Yes/No) If Yes, describe the steps to duplicate the issue.
    yes, plugin will not connect
    Send the debug log to ultrajones@hotmail.com using the procedure below.
    sending via email
      anyone ?
        Can you connect to your Elk M1 System using the Elk RP software? If yes, make sure you have the unsecure port 2101 enabled. As a final test, telnet from your HomeSeer to your Elk M1 XEP on port 2101. Once connected, you should see output from your Elk M1 system.
        Regards,
        Ultrajones
          Solved
          Thanks Ultra.
          Took me a few days but was able to resolve the issue by rebooting the m1xep
          Old adage comes to mind - when in doubt, reboot !
