running HS2 2.5.0.81 std.
Dual processor AMD
System has been stable for a long time but has recently started locking up system. CPU goes to 100% for HomeSeer.exe. Killing process clears up machine.
Upon restart it will run stable (low to med CPU usage, approx 50 threads) for many hours and appears to randomly spike and then lockup.
The only thing I can find is when I enable debug logging. this is from Debug_other.log
2013-11-20_01:31:34:1005: Calling SupportsHS2:UltraM1G
2013-11-20_01:31:35:2225: Calling SetIO:UltraM1G
2013-11-20_01:31:36:8915: UltraM1G Warning~No response/improper response from Elk M1 to command 'az00'
2013-11-20_01:31:38:5275: UltraM1G Error~An unexpected error occured in the ControlZone() function/subroutine: [System.Exception: An invalid action was received.
at HSPI_ULTRAM1G.HSPI.ControlZone(String strZone, String strAction, String strSecret)]
Can anyone elaborate on what I am seeing and if its the issue.
I can't really disable the elk connection as its an integral part of my automation system.
Thanks in advance.
Jeff Bonja
Dual processor AMD
Thanks in advance.
Jeff Bonja
