UltraM1G3 HSPI - Zone Audio
This is a sticky topic.
    #16
    I rebooted the system just to make sure but the errors still persist (less of them though) and the controls are still unresponsive:
    Apr-27 17:39:35 1 Error System.Exception: An invalid audio source number was received. at HSPI_ULTRAM1G3.hspi_plugin.ControlAudioZone(String strZoneNum, AudioCommand AudioCommand, String strAudioSource, String strAudioValue)
    Apr-27 17:39:28 1 Error System.Exception: An invalid audio source number was received. at HSPI_ULTRAM1G3.hspi_plugin.ControlAudioZone(String strZoneNum, AudioCommand AudioCommand, String strAudioSource, String strAudioValue)
    Apr-27 17:38:52 1 Error System.Exception: An invalid audio source number was received. at HSPI_ULTRAM1G3.hspi_plugin.ControlAudioZone(String strZoneNum, AudioCommand AudioCommand, String strAudioSource, String strAudioValue)
    Apr-27 17:38:51 Error Data that caused error in ProcessCommand() subroutine: Len=20, Cmd=CA, Data=01104037050050005000000000, Reserved=00
    Apr-27 17:38:51 1 Error System.FormatException: Input string was not in a correct format. at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) at System.Int32.Parse(String s) at HSPI_ULTRAM1G3.hspi_plugin.ProcessCommand(String strLen, String strCmd, String strData, String strReserved)
    Also....don't mean to bang on but the value/status/graphic and device type/subtype resetting is a bit of an issue for me. Logically things such as blinds should be open/close...not on/off. Because the status pairs get reset when the plugin updates my events stop working too (e.g. 'open' blind at 8am).
    Thanks again for helping out.
    iCore5 Win 10 Pro x64 SSD
    HS3 Pro Edition 3.0.0.435 Windows
    BLOccupied:,Device History:,Yamaha:,UltraMon3:,mcsXap:,Restart:,UltraNetatmo3:, UltraM1G3:,Ultra1Wire3:,BLBackup:,Harmony Hub:,DoorBird:,UltraECM3:,Nanoleaf 3P:,UltraRachio3:,Z-Wave:,SDJ-Health:,BLGarbage:,Blue-Iris:,Chromecast:,Pushover 3P:,EasyTrigger:
      #17
      For now, please update to the latest version to confirm the warnings/errors are gone.
      Ultrajones
        #18
        Yep...the errors have gone. The volume setting are back to the scaling issue (i.e. 40 returns 25 etc). But the 'scaling' is weird. I can't figure it out. It's not a simple scaling of x1.25 or the like.
        I went and changed the volume 1 step at a time and recorded what was returned. I double checked to make sure I wasn't going mad.
        0 -> 0 | 26 -> 16 | 51 -> 35 | 76 -> 67
        1 -> 0 | 27 -> 17 | 52 -> 37 | 77 -> 69
        2 -> 1 | 28 -> 17 | 53 -> 38 | 78 -> 70
        3 -> 1 | 29 -> 19 | 54 -> 40 | 79 -> 72
        4 -> 3 | 30 -> 19 | 55 -> 41 | 80 -> 74
        5 -> 3 | 31 -> 19 | 56 -> 41 | 81 -> 74
        6 -> 3 | 32 -> 20 | 57 -> 43 | 82 -> 75
        7 -> 4 | 33 -> 20 | 58 -> 45 | 83 -> 77
        8 -> 4 | 34 -> 22 | 59 -> 46 | 84 -> 79
        9 -> 6 | 35 -> 22 | 60 -> 48 | 85 -> 80
        10 -> 6 | 36 -> 22 | 61 -> 48 | 86 -> 80
        11 -> 6 | 37 -> 24 | 62 -> 50 | 87 -> 82
        12 -> 8 | 38 -> 24 | 63 -> 51 | 88 -> 83
        13 -> 8 | 39 -> 25 | 64 -> 53 | 89 -> 85
        14 -> 9 | 40 -> 25 | 65 -> 54 | 90 -> 87
        15 -> 9 | 41 -> 25 | 66 -> 54 | 91 -> 87
        16 -> 9 | 42 -> 27 | 67 -> 56 | 92 -> 88
        17 -> 11 | 43 -> 27 | 68 -> 58 | 93 -> 90
        18 -> 11 | 44 -> 29 | 69 -> 59 | 94 -> 91
        19 -> 12 | 45 -> 29 | 70 -> 61 | 95 -> 93
        20 -> 12 | 46 -> 29 | 71 -> 61 | 96 -> 93
        21 -> 12 | 47 -> 30 | 72 -> 62 | 97 -> 95
        22 -> 14 | 48 -> 32 | 73 -> 64 | 98 -> 96
        23 -> 14 | 49 -> 33 | 74 -> 66 | 99 -> 98
        24 -> 16 | 50 -> 35 | 75 -> 67 | 100 -> 100
        The first column is what was set and the second is what is returned.
        To be honest I think this is getting a little bit complicated. I might just have to live with the fact that setting a volume only approximates the actual setting.
        Just a note to say thanks. I think your plugins and support are some of the best around. I have even decided to change my irrigation system from Rain8 (with mcsSprinklers) to Rachio as I am have some problems with mcsSprinklers and am not getting much help. I have ordered the Rachio and will buy your plugin once the Rachio arrives.
        Cheers, Marty
