Seeing the following warn in the log
  • Seeing the following warn in the log
    Dec-02 6:10:38 PM Warning No response/improper response from Elk M1 to command 'ps100'
    Running the latest FW in the M1.
    M1 Firmware: 5.3.10
    M1XEP Firmware: 2.0.42
    M1 Firmware: 5.3.10
    Hi,
    The ps command is a query to the Elk M1 to get the Power Line Carrier (PLC) light status. How often are you seeing that warning in the logs?
    Ultrajones
      Hi,
      Every couple of minutes - I'm also moving Homeseer from Linux to a windows box so this may help?
      I will let you know if things change.
      -Philip
        Update from Windows 7 Box
        Hi,
        I'm seeing the following once an hour or so on the windows box:
        Dec-06 6:08:58 p.m. 1 Error System.FormatException: Additional non-parsable characters are at the end of the string. at System.ParseNumbers.StringToInt(String s, Int32 radix, Int32 flags, Int32* currPos) at System.Convert.ToInt32(String value, Int32 fromBase) at HSPI_ULTRAM1G3.hspi_plugin.ProcessReceived(String strDataRec)
        My system does not have a power line device.
        -Philip
