Your template responses below.
- What Operating System Are You Using: (XP/Vista/7)Linux Zee
- Are you running HomeSeer as a service? (Yes/No)No
- How is HomeSeer connected to the Elk M1? (serial/M1XEP):M1XEP
- Do you run any anti-virus programs? If Yes, indicate the name and version.No
- Describe the issue you are experiencing. Would like to Link Elk M1 Lighting Device to HS Z-Wave Node
- Are you able to duplicate the issue? Yes If Yes, describe the steps to duplicate the issue. View the UltraM1G3 HSPI Lighting Page
- Send the debug log to ultrajones@hotmail.com using the procedure below.
The documentation says: "To create a lighting device, simply connect to the UltraM1G3 HSPI Lighting web page, then select the checkbox next to the lighting number, then click the Submit button". In my case the check boxes are greyed out, so I'm unable to submit.
I've clearly overlooked something.
Since this is a HS Zee, not sure how to grab the UtraM1G debug log from the root directory; I suppose I must ssh into the device.
