There is currently a problem with HS4 that if a device is defined with overlapping Status/Controls/Graphics, neither a script nor plugin can retrieve the device via calls like GetFeaturesByRef. It returns null and generates an error in the HS log. This worked fine under HS3 (equivalent function that is, which still works for these devices). The problem is that for all UltraM1G3 User Features, a single Status/Controls range is defined that is 1-204, and a single Status/Graphics range is defined that is 0-204. I'm sure that HS will eventually fix their code so it does not puke, but I think these devices are also improperly defined. Could you look at it?
In the meantime, I can manually edit these devices for my system. Q: which is correct, 0-204 or 1-204 ?
