Plugin configuration
    I'm a little confused about the plugin configuration. I'm running version 3.0.0.15 with a Vista20P panel, with four keypads and an AD2USB. I'm looking at the Help page of the plugin and it refers to "Keypad addresses" that I need to enter in the 'Interface Address' on the Settings tab, and also in the 'Device Address' in the Partitions tab.
    However, in speaking with ADT they confirmed that none of my keypads (I have four) have keypad addresses - only the security devices have addresses.
    Furthermore, the plugin seems to work when I enter Zone 18 into both fields on the two tabs - despite the fact that Zone 18 is assigned to a motion detector in my kitchen. And the plugin properly picks up motion activity on Zone 18 when configured this way.
    There's also something else that seems strange: the 'Arm Away' value in my System Status and Partition 1 devices in Homeseer is still set to 103 (I did not change it to 106 as instructed) and I am still able to set the Alarm to Arm Away from Homeseer.
    The instructions for the plugin refer to version 1.27, and I've been unable to find more up-to-date instructions, so my apologies if all of this is explained in a newer help file somewhere - if it is, could you point me to it? If not, any ideas as to what is causing this behavior?
    I'm not asking about all of this because I'm intentionally trying to find weaknesses in the plugin (!) - I'm very much of the school of "if it ain't broke don't fix it." However, as I documented in another post, I am receiving a nearly constant stream of 'Skipping bad message' entries in my Homeseer log file, and while I understand from you that this is not causing any problem in functionality it is making my log file unusable. If I could find a way to stop the logging I probably would't care about these other issues other than to simply be curious about them - and perhaps the info will be helpful to you as you continue to develop the plugin.
    Any thoughts you have would be appreciated.
    Regards.
    Thanks.
    please update to the latest beta available in the beta section of the Updater.
    how many partitions do you have?
    Please post some screen shots of the plugin config tabs?
    the plugin configuration hasn't really changed since V1.x. the basic instructions should work.
    Each keypad has a unique address from 16 to 23. I suppose if you only have one partition, they could all have the same address; not sure. these are not wireless device address.
    Mark
    HS3 Pro 3.0.0.534
      I have a single partition. I just upgraded to beta version .27 to see if that would make a difference (it doesn't).
      I've attached screenshots of the Settings tab and the Partitions tab. Hope this is helpful.
        I think I see the problem - I have keypads at addresses 16, 17 and 18, and devices at zones 1 through 40.
        Given this, I'm still a little confused as to how I fill in the 'Interface address' on the Settings tab, and the 'Device Address' on the Partitions tab. Can you advise?
        Thanks in advance.
          Thanks in advance.
          yes, keypad address and zone numbers are different
          do you know what address you have the ad2usb set to? that is what you need for the interface address setting
          you can probably use address 16 on the partition 1 setup
          Mark
          HS3 Pro 3.0.0.534
            I think I have figured it out. My alarm panel was only configured for three keypads (at 16, 17 and 18, all of which are real keypads) - so the AD2USB did not have its own unique address. I'm hoping that this "overlapping" is what is causing the bad messages in my log file.
            I've added a fourth keypad address (19) to the system and set the Interface address to 19, and I can control the panel from Homeseer, so the plugin appears to be working properly. Now I need to see if the bad messages disappear from my log file.
            Thanks for your help in resolving this, I appreciate it.
              Glad you got it working. Let me know if the 'bad messages' disappear; I bet they will.
              Mark
              HS3 Pro 3.0.0.534
                I thought they would also, but they have not. The Interface Address is configured to address 19 (unique - no other keypad on that address) and I've tried the Device address set to 16, 17 and 18 (where my existing keyboards are located) and in all three cases I get the error messages. I'm going to try setting the Device Address to 19 - the same as the Interface Address - to see if that works better. I'll post the results ...
                EDIT:
                No impact - I get the 'Skipping bad message' message repeatedly using all possible keyboard addresses. Is there any way to filter out these messages, by any chance?
                  using the hs3 log filter feature, can you post a log snippet of just the Vista Alarm log entries including the 'bad messages' you are referring to. I would like to see good messages that look similar as well. you will need to enable debug mode in the plugin so see the raw ad2usb msgs.
                  I'm curious why you are getting so many of these
                  Mark
                  HS3 Pro 3.0.0.534
                    Sure - I'll turn on debug mode and wait a day, then post the filtered log messages. Current log doesn't have much in it - we just recovered from a long power failure.
                      I'm posting the log file, the bottom (earlier) half of which is in debug mode, filtered for messages only from the plugin - perhaps this can help you figure out what is going wrong. Apologies for the length of the snippet:
                      Date/Time Pri Type/Error Message/Source
                      Mar-03 7:21:04 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 7:10:52 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-03 7:05:12 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 6:59:17 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 6:58:18 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 6:57:24 AM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-03 6:57:15 AM Vista Alarm Skipping bad message: [1000MED CHIME Ready to Arm "
                      Mar-03 6:56:51 AM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-03 6:56:38 AM Vista Alarm FAULT 11 FRONT DOOR
                      Mar-03 6:56:31 AM Vista Alarm FAULT 17 LIBRARYMOTION
                      Mar-03 6:56:17 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-03 6:53:14 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-03 6:27:50 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 6:22:14 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 6:21:44 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 6:03:06 AM Vista Alarm Skipping bad message: [1000000110000000---dy to Arm "
                      Mar-03 6:00:17 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 5:58:28 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 5:57:52 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-03 5:56:02 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 5:53:24 AM Vista Alarm Skipping bad message: [1000000110000000----],008,rm "
                      Mar-03 5:47:18 AM Vista Alarm Skipping bad message: [1SARMED CHIME Ready to Arm "
                      Mar-03 5:43:52 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-03 5:42:32 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 5:33:47 AM Vista Alarm Skipping bad message: [100000011000E Ready to Arm "
                      Mar-03 5:29:39 AM Vista Alarm Skipping bad message: [10ARMED CHIME Ready to Arm "
                      Mar-03 5:28:40 AM Vista Alarm Skipping bad message: [10000ED CHIME Ready to Arm "
                      Mar-03 5:25:42 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 5:21:05 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 5:20:45 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 5:16:47 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 5:15:28 AM Vista Alarm Skipping bad message: [100000011000E Ready to Arm "
                      Mar-03 5:04:45 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 5:03:55 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 4:49:34 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 4:48:35 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 4:48:15 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 4:47:15 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 4:46:16 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 4:45:07 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 4:44:57 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 4:40:59 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 4:15:45 AM Vista Alarm Skipping bad message: [1000000110000000----],008,[m "
                      Mar-03 4:09:29 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 3:57:56 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 3:57:06 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 3:50:01 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 3:39:37 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 3:37:18 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 3:31:02 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 3:30:42 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 3:22:27 AM Vista Alarm Skipping bad message: [ISARMED CHIME Ready to Arm "
                      Mar-03 3:19:39 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 2:54:34 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 2:47:39 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 2:46:10 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 2:36:06 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 2:29:30 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 2:12:40 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 2:02:46 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 1:51:53 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 1:49:34 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 1:45:27 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 1:39:31 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 1:36:42 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 1:19:13 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 1:16:35 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 1:14:56 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 1:03:33 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 12:57:26 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 12:55:28 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 12:53:49 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 12:43:55 AM Vista Alarm Skipping bad message: [1SARMED CHIME Ready to Arm "
                      Mar-03 12:35:40 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 12:35:30 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 12:32:41 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 12:28:34 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 12:17:41 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 12:12:44 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-03 12:11:25 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:56:24 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:55:14 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:45:40 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:42:22 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:35:46 PM Vista Alarm Skipping bad message: [1000000110000000---dy to Arm "
                      Mar-02 11:30:59 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:17:28 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:14:49 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:13:50 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:12:11 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:10:28 PM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 11:10:23 PM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 11:09:35 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 10:58:19 PM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 10:58:19 PM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 10:52:31 PM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 10:47:47 PM Vista Alarm Skipping bad message: AULT 18 KITCHENMOTION "
                      Mar-02 10:45:25 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 10:41:04 PM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 10:41:01 PM Vista Alarm Sending Display Faults command to alarm
                      Mar-02 10:41:01 PM Vista Alarm DISARMED CHIME Hit * for faults
                      Mar-02 10:40:55 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 10:39:32 PM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 10:39:15 PM Vista Alarm DISARM SYSTEM or alarm occurs
                      Mar-02 10:29:16 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 10:24:49 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 10:23:30 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 10:23:10 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 10:12:03 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 9:29:15 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 9:27:56 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 9:26:27 PM Vista Alarm Skipping bad message: [0010000110000000- "
                      Mar-02 9:17:12 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 9:15:53 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 9:12:15 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 9:06:58 PM Vista Alarm Skipping bad message: [001000011000** "
                      Mar-02 9:02:01 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 8:58:53 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 8:58:44 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 8:52:57 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 8:49:49 PM Vista Alarm Skipping bad message: [001000011000000 "
                      Mar-02 8:38:36 PM Vista Alarm Skipping bad message: [00100001100*** "
                      Mar-02 8:36:47 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 8:33:49 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 8:30:31 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 8:28:12 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 8:23:15 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 8:18:28 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 8:15:50 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 8:14:31 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 8:08:34 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 8:08:24 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 8:05:36 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 7:56:32 PM Vista Alarm Skipping bad message: RMED ***STAY*** "
                      Mar-02 7:56:02 PM Vista Alarm ARMED ***STAY***
                      Mar-02 7:55:02 PM Vista Alarm ARMED ***STAY***You may exit now
                      Mar-02 7:54:43 PM Vista Alarm ARMED ***STAY***
                      Mar-02 7:53:44 PM Vista Alarm ARMED ***STAY***You may exit now
                      Mar-02 7:53:37 PM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 7:53:30 PM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 7:51:25 PM Vista Alarm Skipping bad message: AULT 31 MUDROOMMOTION "
                      Mar-02 7:49:56 PM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 7:47:51 PM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 7:47:48 PM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 7:47:48 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:45:10 PM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 7:25:40 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:25:10 PM Vista Alarm Skipping bad message: [10000001CHIME Ready to Arm "
                      Mar-02 7:22:35 PM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 7:18:22 PM Vista Alarm Skipping bad message: [100000011HIME Ready to Arm "
                      Mar-02 7:14:55 PM Vista Alarm Skipping bad message: [10ARMED CHIME Ready to Arm "
                      Mar-02 7:14:05 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:06:20 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:05:30 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:05:20 PM Vista Alarm Skipping bad message: [10000001100ME Ready to Arm "
                      Mar-02 7:01:56 PM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 6:54:55 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 6:50:58 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 6:47:20 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 6:36:48 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 6:31:32 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 6:26:47 PM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 6:26:35 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 6:12:41 PM Vista Alarm Skipping bad message: [10000ED CHIME Ready to Arm "
                      Mar-02 6:12:37 PM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 6:12:27 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 6:09:59 PM Vista Alarm Skipping bad message: [ISARMED CHIME Ready to Arm "
                      Mar-02 6:05:19 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 6:03:28 PM Vista Alarm Skipping bad message: [100000011000E Ready to Arm "
                      Mar-02 6:00:50 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:55:13 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:52:21 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:47:42 PM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 5:46:49 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:41:59 PM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 5:41:49 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:40:00 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:39:26 PM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 5:38:55 PM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 5:38:42 PM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 5:36:46 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:34:20 PM Vista Alarm Skipping bad message: AULT 18 KITCHENMOTION "
                      Mar-02 5:28:48 PM Vista Alarm Skipping bad message: [ISARMED CHIME Ready to Arm "
                      Mar-02 5:28:45 PM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 5:28:03 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:27:47 PM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 5:22:01 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:19:13 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:19:03 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:17:34 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:17:14 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:59:48 PM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 4:59:15 PM Vista Alarm FAULT 17 LIBRARYMOTION
                      Mar-02 4:57:40 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:55:51 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:47:15 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:42:11 PM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 4:40:30 PM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 4:40:23 PM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 4:39:57 PM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 4:39:35 PM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 4:36:54 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:31:18 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:28:09 PM Vista Alarm Skipping bad message: [1000000110IME Ready to Arm "
                      Mar-02 4:26:11 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:23:03 PM Vista Alarm Skipping bad message: [1000000110000000----],00 Arm "
                      Mar-02 4:21:56 PM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 4:12:30 PM Vista Alarm Skipping bad message: [1000000110000000---dy to Arm "
                      Mar-02 4:01:17 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:58:52 PM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 3:53:04 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:45:14 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:45:04 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:42:59 PM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 3:42:56 PM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 3:41:57 PM Vista Alarm FAULT 36 GARAGE PEDESTRIAN DOOR
                      Mar-02 3:41:49 PM Vista Alarm FAULT 36 GARAGE PEDESTRIAN DOOR
                      Mar-02 3:32:59 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:31:36 PM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 3:31:25 PM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 3:31:25 PM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 3:30:58 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:25:41 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:24:52 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:20:54 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:08:42 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:01:56 PM Vista Alarm Skipping bad message: [10ARMED CHIME Ready to Arm "
                      Mar-02 2:55:20 PM Vista Alarm Skipping bad message: [1SARMED CHIME Ready to Arm "
                      Mar-02 2:55:00 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:50:03 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:49:24 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:46:16 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:39:40 PM Vista Alarm Skipping bad message: [ISARMED CHIME Ready to Arm "
                      Mar-02 2:35:22 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:31:45 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:29:35 PM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 2:25:55 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:17:11 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:12:24 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:11:54 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:05:30 PM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 2:05:27 PM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 2:05:23 PM Vista Alarm Skipping bad message: [000000011DROOMGARAGE DOOR "
                      Mar-02 2:05:19 PM Vista Alarm Skipping bad message: AULT 38 MUDROOMGARAGE DOOR "
                      Mar-02 2:04:07 PM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 2:03:49 PM Vista Alarm Skipping bad message: AULT 31 MUDROOMMOTION "
                      Mar-02 1:59:13 PM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 1:55:34 PM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 1:55:32 PM Vista Alarm FAULT 17 LIBRARYMOTION
                      Mar-02 1:54:11 PM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 1:54:10 PM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 1:53:47 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 1:23:35 PM Vista Alarm Skipping bad message: [10000001100000 Ready to Arm "
                      Mar-02 1:13:31 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 1:07:15 PM Vista Alarm Skipping bad message: [10000001100ME Ready to Arm "
                      Mar-02 1:02:58 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 12:51:05 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 12:49:46 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 12:47:37 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 12:45:29 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 12:42:11 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 12:41:11 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 12:38:53 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 12:36:24 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 12:24:47 PM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 12:24:43 PM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 12:23:49 PM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 12:23:18 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 12:21:13 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 12:16:26 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 12:16:19 PM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 12:12:16 PM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 12:03:16 PM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:58:02 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 11:55:45 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:53:56 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:53:17 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:49:29 AM Vista Alarm Skipping bad message: [10000001100000 Ready to Arm "
                      Mar-02 11:46:31 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:35:27 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:33:48 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:28:35 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:18:33 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:15:44 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:04:49 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 11:03:40 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 10:59:34 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 10:58:15 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 10:57:12 AM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 10:57:07 AM Vista Alarm Skipping bad message: [10000001CHIME Ready to Arm "
                      Mar-02 10:51:29 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 10:42:25 AM Vista Alarm Skipping bad message: [1000000110000000----y to Arm "
                      Mar-02 10:41:58 AM Vista Alarm AC LOSS
                      Mar-02 10:37:06 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 10:36:54 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 10:35:41 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 10:35:01 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 10:29:23 AM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 10:29:16 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 10:25:23 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 10:22:47 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 10:19:54 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 10:03:53 AM Vista Alarm Skipping bad message: [1000000110000000-eady to Arm "
                      Mar-02 9:58:37 AM Vista Alarm Skipping bad message: [1000000110000000----y to Arm "
                      Mar-02 9:58:17 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 9:56:38 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 9:54:09 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 9:53:59 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 9:50:14 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 9:49:33 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 9:48:14 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 9:42:55 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 9:42:16 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 9:40:06 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 9:38:38 AM Vista Alarm Skipping bad message: [100000011HIME Ready to Arm "
                      Mar-02 9:35:59 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 9:33:45 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 9:30:30 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 9:24:45 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 9:22:50 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 9:13:00 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 9:06:19 AM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 9:05:28 AM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 9:05:16 AM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 9:04:57 AM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 9:04:33 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 9:04:00 AM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 9:02:12 AM Vista Alarm FAULT 15 KITCHENDOOR
                      Mar-02 9:00:50 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 8:58:48 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 8:56:54 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 8:50:44 AM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 8:50:41 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 8:47:42 AM Vista Alarm Skipping bad message: [10000001100ME Ready to Arm "
                      Mar-02 8:46:36 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 8:32:26 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 8:31:56 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 8:31:49 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 8:27:56 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 8:23:18 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 8:15:53 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 8:13:44 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 8:12:01 AM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 8:11:57 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 8:07:14 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 8:04:14 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 8:02:35 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:59:58 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:59:18 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:57:20 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:55:15 AM Vista Alarm Skipping bad message: AULT 18 KITCHENMOTION "
                      Mar-02 7:55:07 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:52:52 AM Vista Alarm Skipping bad message: AULT 18 KITCHENMOTION "
                      Mar-02 7:49:19 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:46:09 AM Vista Alarm FAULT 37 MUDROOMDOOR
                      Mar-02 7:45:52 AM Vista Alarm FAULT 37 MUDROOMDOOR
                      Mar-02 7:45:39 AM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 7:45:34 AM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 7:44:18 AM Vista Alarm FAULT 38 MUDROOMGARAGE DOOR
                      Mar-02 7:43:50 AM Vista Alarm DISARMED CHIME Ready to Arm
                      Mar-02 7:43:46 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 7:43:43 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:43:06 AM Vista Alarm Skipping bad message: 4RFX:0881271,04
                      Mar-02 7:41:55 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 7:39:27 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:29:43 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:24:56 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:17:51 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:11:54 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 7:11:47 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 6:57:25 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 6:56:18 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 6:54:07 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 6:48:21 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 6:38:35 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 6:29:16 AM Vista Alarm FAULT 11 FRONT DOOR
                      Mar-02 6:29:11 AM Vista Alarm FAULT 17 LIBRARYMOTION
                      Mar-02 6:29:01 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 6:26:12 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 6:19:29 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 6:12:41 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 6:06:25 AM Vista Alarm Skipping bad message: [1000000110000000----] to Arm "
                      Mar-02 6:02:27 AM Vista Alarm Skipping bad message: [1000000110000000-eady to Arm "
                      Mar-02 5:51:07 AM Vista Alarm FAULT 31 MUDROOMMOTION
                      Mar-02 5:50:27 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:48:18 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:45:50 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:43:11 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:31:58 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:30:49 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 5:02:56 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:56:50 AM Vista Alarm Skipping bad message: [100000D CHIME Ready to Arm "
                      Mar-02 4:51:43 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:46:16 AM Vista Alarm Skipping bad message: [1000000110000000----],008,rm "
                      Mar-02 4:41:49 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:30:46 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:27:28 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:22:41 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:13:56 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:12:57 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:09:58 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:04:42 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 4:04:32 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:44:34 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:41:06 AM Vista Alarm Skipping bad message: [1000000110000 Ready to Arm "
                      Mar-02 3:38:57 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:24:06 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:20:29 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:16:31 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:14:52 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:13:06 AM Vista Alarm FAULT 30 FRONT HALL MOTION
                      Mar-02 3:06:24 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:06:04 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 3:05:25 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:54:11 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:52:52 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:49:34 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:38:31 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:34:34 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:29:56 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:28:47 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 2:06:19 AM Vista Alarm Settings page submitted
                      Mar-02 2:06:11 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:06:11 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:06:11 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:06:08 AM Vista Alarm 0893830,04
                      Mar-02 2:06:01 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:06:01 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:06:01 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:05:51 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:05:51 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:05:51 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:05:41 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:05:41 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:05:41 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:05:31 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:05:31 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:05:31 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:05:30 AM Vista Alarm 0098743,84
                      Mar-02 2:05:21 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:05:21 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:05:21 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:05:12 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:05:12 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:05:12 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:05:02 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:05:02 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:05:02 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:04:52 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:04:52 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:04:52 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:04:42 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:04:42 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:04:42 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:04:32 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:04:32 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:04:32 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:04:26 AM Vista Alarm 0947254,84
                      Mar-02 2:04:22 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:04:22 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:04:22 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:04:12 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:04:12 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:04:12 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:04:02 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:04:02 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:04:02 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:04:00 AM Vista Alarm 0442332,04
                      Mar-02 2:03:52 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:03:52 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:03:52 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:03:42 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:03:42 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:03:42 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:03:33 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:03:33 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:03:33 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:03:24 AM Vista Alarm 0574785,04
                      Mar-02 2:03:23 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:03:23 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:03:23 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:03:13 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:03:13 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:03:13 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:03:03 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:03:03 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:03:03 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:02:55 AM Vista Alarm 0551282,04
                      Mar-02 2:02:53 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:02:53 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:02:53 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:02:43 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:02:43 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:02:43 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:02:38 AM Vista Alarm 0762774,04
                      Mar-02 2:02:33 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:02:33 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:02:33 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:02:23 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:02:23 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:02:23 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:02:13 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:02:13 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:02:13 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:02:03 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:02:03 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:02:03 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:01:59 AM Vista Alarm 0980746,04
                      Mar-02 2:01:54 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:01:54 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:01:54 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:01:52 AM Vista Alarm 0133625,04
                      Mar-02 2:01:44 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:01:44 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:01:44 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:01:34 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:01:34 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:01:34 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:01:24 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:01:24 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:01:24 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:01:14 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:01:14 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:01:14 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:01:10 AM Vista Alarm 0772706,04
                      Mar-02 2:01:04 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:01:04 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:01:04 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:00:54 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:00:54 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:00:54 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:00:44 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:00:44 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:00:44 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:00:40 AM Vista Alarm 0537335,04
                      Mar-02 2:00:34 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:00:34 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:00:34 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:00:24 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:00:24 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:00:24 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:00:15 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:00:15 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:00:15 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 2:00:14 AM Vista Alarm 0361946,84
                      Mar-02 2:00:05 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 2:00:05 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 2:00:05 AM Vista Alarm D1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:59:55 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:59:55 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:59:55 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:59:48 AM Vista Alarm 0881252,04
                      Mar-02 1:59:45 AM Vista Alarm 0005323,84
                      Mar-02 1:59:45 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:59:45 AM Vista Alarm [100000011000000 ----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:59:45 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:59:43 AM Vista Alarm 0124316,14
                      Mar-02 1:59:35 AM Vista Alarm D1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:59:35 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:59:35 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:59:25 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:59:25 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:59:25 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:59:15 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:59:15 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:59:15 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:59:05 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:59:05 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:59:05 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:58:55 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:58:55 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:58:55 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:58:45 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:58:45 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:58:45 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:58:36 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:58:36 AM Vista Alarm D1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:58:36 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:58:26 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:58:26 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:58:26 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:58:16 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:58:16 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:58:16 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:58:06 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:58:06 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:58:06 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:57:56 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:57:56 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:57:56 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:57:55 AM Vista Alarm 1043332,a4
                      Mar-02 1:57:47 AM Vista Alarm 0515778,34
                      Mar-02 1:57:46 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:57:46 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:57:46 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:57:36 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:57:36 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:57:36 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:57:26 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:57:26 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:57:26 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:57:24 AM Vista Alarm 0751365,04
                      Mar-02 1:57:16 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:57:16 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:57:16 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:57:06 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:57:06 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:57:06 AM Vista Alarm D1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:57:04 AM Vista Alarm 0959882,04
                      Mar-02 1:56:57 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:56:57 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:56:57 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:56:47 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:56:47 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:56:47 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:56:37 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:56:37 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:56:37 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:56:27 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:56:27 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:56:27 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:56:17 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:56:17 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:56:17 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:56:07 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:56:07 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:56:07 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:55:57 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:55:57 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:55:57 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:55:53 AM Vista Alarm 0152932,34
                      Mar-02 1:55:47 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:55:47 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:55:47 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:55:37 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:55:37 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:55:37 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:55:27 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:55:27 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:55:27 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:55:18 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:55:18 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:55:18 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:55:08 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:55:08 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:55:08 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:55:03 AM Vista Alarm 0238370,04
                      Mar-02 1:54:58 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:54:58 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:54:58 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:54:48 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:54:48 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:54:48 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:54:38 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:54:38 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:54:38 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:54:28 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:54:28 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:54:28 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:54:20 AM Vista Alarm 0191815,04
                      Mar-02 1:54:19 AM Vista Alarm 0194368,04
                      Mar-02 1:54:18 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:54:18 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:54:18 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:54:08 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:54:08 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:54:08 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:53:58 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:53:58 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:53:58 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:53:48 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:53:48 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:53:48 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:53:48 AM Vista Alarm 1016005,04
                      Mar-02 1:53:39 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:53:39 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:53:39 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:53:29 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:53:29 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:53:29 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:53:19 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:53:19 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:53:19 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:53:09 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:53:09 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:53:09 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:52:59 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:52:59 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:52:59 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:52:49 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:52:49 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:52:49 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:52:43 AM Vista Alarm 0849900,24
                      Mar-02 1:52:39 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:52:39 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:52:39 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:52:29 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:52:29 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:52:29 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:52:19 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:52:19 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:52:19 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:52:15 AM Vista Alarm 0269054,84
                      Mar-02 1:52:10 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:52:10 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:52:10 AM Vista Alarm D1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:52:09 AM Vista Alarm 0887424,04
                      Mar-02 1:52:00 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:52:00 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:52:00 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:51:50 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:51:50 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:51:50 AM Vista Alarm D1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:51:40 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:51:40 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:51:40 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:51:30 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:51:30 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:51:30 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:51:20 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:51:20 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:51:20 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:51:10 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:51:10 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:51:10 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:51:00 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:51:00 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:51:00 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:50:50 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:50:50 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:50:50 AM Vista Alarm D1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:50:40 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:50:40 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:50:40 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:50:31 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:50:31 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:50:31 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:50:23 AM Vista Alarm 0827126,34
                      Mar-02 1:50:21 AM Vista Alarm Skipping bad message: [1000000110000 Ready to Arm "
                      Mar-02 1:50:11 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:50:11 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:50:11 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:50:06 AM Vista Alarm 0749953,04
                      Mar-02 1:50:01 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:50:01 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:50:01 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:49:51 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:49:51 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:49:51 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:49:41 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:49:41 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:49:41 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:49:31 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:49:31 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:49:31 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:49:21 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:49:21 AM Vista Alarm D1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:49:21 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:49:18 AM Vista Alarm 0487944,04
                      Mar-02 1:49:11 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:49:11 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:49:11 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:49:01 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:49:01 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:49:01 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:48:52 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:48:52 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:48:52 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:48:42 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:48:42 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:48:42 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:48:32 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:48:32 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:48:32 AM Vista Alarm 01000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:48:23 AM Vista Alarm 0913496,34
                      Mar-02 1:48:22 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:48:22 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:48:22 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:48:12 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:48:12 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:48:12 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:48:06 AM Vista Alarm 0945470,04
                      Mar-02 1:48:02 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:48:02 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:48:02 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:47:52 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:47:52 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:47:52 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:47:42 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:47:42 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:47:42 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:47:32 AM Vista Alarm Dumping bad message: [1000000110000000----],008,[f7 0000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:47:22 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:47:22 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:47:22 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:47:21 AM Vista Alarm 0992400,04
                      Mar-02 1:47:13 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:47:13 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:47:13 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:47:03 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:47:03 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:47:03 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:47:02 AM Vista Alarm 0615860,24
                      Mar-02 1:47:01 AM Vista Alarm 0646415,04
                      Mar-02 1:46:53 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:46:53 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:46:53 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:46:52 AM Vista Alarm 1017554,04
                      Mar-02 1:46:45 AM Vista Alarm 0324385,04
                      Mar-02 1:46:43 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:46:43 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:46:43 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:46:33 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:46:33 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:46:33 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:46:32 AM Vista Alarm 0592516,24
                      Mar-02 1:46:25 AM Vista Alarm 0644191,24
                      Mar-02 1:46:23 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:46:23 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:46:23 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:46:13 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:46:13 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:46:13 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:46:03 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 1:46:00 AM Vista Alarm 0126492,24
                      Mar-02 1:45:55 AM Vista Alarm 0063512,04
                      Mar-02 1:45:53 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:45:53 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:45:53 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:45:52 AM Vista Alarm 0897190,04
                      Mar-02 1:45:48 AM Vista Alarm 0679476,84
                      Mar-02 1:45:43 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:45:43 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:45:43 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:45:34 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:45:34 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:45:34 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:45:33 AM Vista Alarm 0896477,24
                      Mar-02 1:45:24 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:45:24 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:45:24 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:45:18 AM Vista Alarm 0493976,04
                      Mar-02 1:45:14 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:45:14 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:45:14 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:45:04 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 1:44:54 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 1:44:44 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:44:44 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:44:44 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:44:43 AM Vista Alarm 0431761,84
                      Mar-02 1:44:34 AM Vista Alarm Skipping bad message: DISARMED CHIME Ready to Arm "
                      Mar-02 1:44:24 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:44:24 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:44:24 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:44:14 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:44:14 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:44:14 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:44:04 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:44:04 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:44:04 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:43:55 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:43:55 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:43:55 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:43:45 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:43:45 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:43:45 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                      Mar-02 1:43:38 AM Vista Alarm 0535017,04
                      Mar-02 1:43:35 AM Vista Alarm MessageKey=DISARMED CHIME Ready to Arm 1
                      Mar-02 1:43:35 AM Vista Alarm Processing msg on Partition 1
                      Mar-02 1:43:35 AM Vista Alarm [1000000110000000----],008,[f700000f1008001c28020000000000]," DISARMED CHIME Ready to Arm "
                        what fw ver do you have installed on your ad2usb? you can see this in the hs log when the plugin starts
                        I can fix this "bad msg" issue in the plugin, but its strange that your 20p is generating msgs that are different length than my 20p, or my test 10se.
                        Mark
                        HS3 Pro 3.0.0.534
                          one additional request to capture some ad2usb msgs:
                          1. goto the hs3 plugin manage page
                          2. disable the plugin
                          3. enable developer mode at the top
                          4. enable the plugin; a console window will appear with ad2usb msgs
                          please copy and paste a few of the msgs here
                          after, you can reverse the above procedure to get rid of the console window
                          Mark
                          HS3 Pro 3.0.0.534
                            I'm running firmware version 2.2a.6 on the AD2USB. Should I upgrade to a new version of the firmware? I'll try to do so now.
                            I am unable to open a console window for the plugin - I suspect there may be an error in the plugin when it is operating in developer mode AND the user is not using COM1. I am using COM3, which works fine. However, when I follow your instructions (disable the plugin, select developer mode, re-enable the plugin) the plugin fails to restart properly, and I get the following error in the log file:
                            Mar-04 3:03:24 PM	 	Error	Initializing plug-in(1): Vista Alarm Instance::Error opening COM port COM1 to Vista Alarm
                            Mar-04 3:03:24 PM	 	Vista Alarm	Error: System.IO.IOException: The port 'COM1' does not exist. at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str) at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace) at System.IO.Ports.SerialPort.Open() at HSPI_VistaAlarm.MSSerialPortClass.Open() at HSPI_VistaAlarm.VistaAlarmClass.OpenPort(String Port) [3.0.0.27]
                            EDIT: I tried uploading the newest stable version of the firmware (2.2a.8.2). Nothing seemed to happen, and I received the following message in the log file from the plugin:
                            Mar-04 3:13:09 PM	 	Vista Alarm	Nothing To process...this should Not occur
                            Mar-04 3:12:43 PM	 	Vista Alarm	Nothing To process...this should Not occur
                              you may need to reconfig the ad2usb. from the settings page in the config, click Save Settings and retest. if this doesn't work, stop the plugin, and open a putty window to get the ad2usb online. reboot the plugin, and then check the settings.
                              Mark
                              HS3 Pro 3.0.0.534
