Possible bug?
  • Possible bug?
    I have noticed a situation that happens.
    I have a wireless zone that has been causing me issues. A couple times a day it doesn't check in and then I get the check 20:
         May-12 9:51:11 AM  Vista Alarm CHECK 20 MASTER BEDROOM WINDOW
    Basically once this happens I am locked out of any hard wired zone triggers from working until I bypass the zone and hit *
    May-13 12:35:23 AM	 	Vista Alarm	FAULT 14 BACK DOOR
    May-13 12:35:19 AM	 	Vista Alarm	FAULT 09 MASTER BATHROOM WINDOW
    May-13 12:35:18 AM	 	Vista Alarm	Sending Button Send command to alarm
    May-13 12:35:10 AM	 	Vista Alarm	DISARMED BYPASS Hit * for faults
    May-13 12:35:08 AM	 	Vista Alarm	0739396,00 received from Stairway Stairway IR RF
    May-13 12:35:05 AM	 	Vista Alarm	0739396,80 received from Stairway Stairway IR RF
    May-13 12:35:03 AM	 	Vista Alarm	BYPAS
    May-13 12:35:02 AM	 	Vista Alarm	Sending BypassZone command to alarm
    May-13 12:34:49 AM	 	Vista Alarm	Sending Button Send command to alarm
    You can see here from the logs that I bypass the zone. It then says Disarmed Bypass Hit *for faults. As soon as I press the * you see it registers that the back door and master bathroom window are open. Note: they were open from the beginning.
    I use the backdoor trigger to turn on outside lights at night and I noticed it hasn't been working. I think I figured out that when the check 20 happens, it basically locks up any events from acting on zone faults until the check 20 is cleared and the * is pressed.
    I had a similar issue. I had to replace the RF sensor.
    Mark
    HS3 Pro 3.0.0.534
      Yeah, I am definitely going to replace the sensor, however is there way to get the triggers working no matter what? the board will still react to alarms signals so it must be sending the fault signals but the plugin not registering them
      Not sure...
        I'm not really sure this scenario is worth the effort. but if you can post a debug log that shows the panel messages that are getting missed, I will take a look
        Mark
        HS3 Pro 3.0.0.534
