Error?
  • Error?
    Hi,
    Noticed this (ERROR Trouble handling last message...) in my log tonight
    Jun-22 11:01:32 PM	 	Vista Alarm	ARMED ***STAY** ZONE BYPASSED
    Jun-22 11:00:34 PM	 	Vista Alarm	ARMED ***STAY** You may exit now
    Jun-22 11:00:34 PM	 	Vista Alarm	Sending Goto Partition 0 command to alarm
    Jun-22 11:00:32 PM	 	Vista Alarm	Sending Arm Stay command to alarm
    Jun-22 11:00:30 PM	 	Vista Alarm	Sending Goto Partition 1 command to alarm
    Jun-22 10:56:53 PM	 	Vista Alarm	Trouble handling last msg: [1001000100000000----],011,[f74f04001011801c08020000000000]," MORTON RES READY TO ARM "
    Jun-22 10:56:53 PM	 	Vista Alarm	Error: System.InvalidOperationException: Collection was modified; enumeration operation may not execute. at System.Collections.Hashtable.HashtableEnumerator.MoveNext() at HSPI_VistaAlarm.VistaAlarmClass.ZonesCollection.UpdateClearedZones(MessageCollection& Messages, Boolean BypassMode, PartitionClass Partition) at HSPI_VistaAlarm.VistaAlarmClass.ProcessMessage(String Buffer) [3.0.0.15]
    Jun-22 10:50:39 PM	 	Vista Alarm	FAULT 11 FRONT HALL MOTION
    Jun-22 10:47:58 PM	 	Vista Alarm	Error: System.InvalidOperationException: Collection was modified; enumeration operation may not execute. at System.Collections.Hashtable.HashtableEnumerator.MoveNext() at HSPI_VistaAlarm.VistaAlarmClass.ZonesCollection.UpdateClearedZones(MessageCollection& Messages, Boolean BypassMode, PartitionClass Partition) at HSPI_VistaAlarm.VistaAlarmClass.ProcessMessage(String Buffer) [3.0.0.15]
    Jun-22 10:47:58 PM	 	Vista Alarm	Trouble handling last msg: [0101000110000000----],016,[f71000002016800c2c020000000000],"ARMED ***AWAY***** ALL SECURE **"
    Jun-22 10:47:09 PM	 	Vista Alarm	FAULT 11 FRONT HALL MOTION
    Jun-22 10:46:36 PM	 	Vista Alarm	FAULT 11 FRONT HALL MOTION
    Jun-22 10:46:27 PM	 	Vista Alarm	FAULT 10 DINING ROOM MOTION
    Jun-22 10:46:19 PM	 	Vista Alarm	FAULT 10 DINING ROOM MOTION
    Jun-22 10:46:00 PM	 	Vista Alarm	FAULT 10 DINING ROOM MOTION
    Jun-22 10:45:57 PM	 	Vista Alarm	FAULT 11 FRONT HALL MOTION
    Jun-22 10:45:53 PM	 	Vista Alarm	FAULT 11 FRONT HALL MOTION
    Jun-22 10:45:48 PM	 	Vista Alarm	FAULT 11 FRONT HALL MOTION
    I was going to reboot the system but the plugin got itself together and seems to be behaving.
    -r
    HS3 Pro Edition 3.0.0.318 (Windows)
    Is Registered
    Microsoft Windows Embedded Standard - Work Station
    6.1.7601 Service Pack: 1.0
    12 Days 5 Hours 25 Minutes 23 Seconds
    Vista plugin 3.0.0.15
    Panel is a Vista 40 2 partitions.
    -Rick
    please update to the latest beta in the updater. I think I fixed this error recently
    Mark
    HS3 Pro 3.0.0.534
      Perhaps this is obvious to some, but by Updater, do you mean under the tab plugins - managed: a list of installed plugin appears with version info. Beneath that is a list of plugins. No beta though.
      -r
      -Rick
        -r
        yes, you are in the right place, there is a "Beta" section at the bottom
        Mark
        HS3 Pro 3.0.0.534
        Unconfigured PHP Module
