Custom message script problem
  • #16
    Glad to help. Thanks for testing the latest betas and posting feedback.
    Mark
    HS3 Pro 3.0.0.534
    • #17
      Mark,
      Everything seems pretty stable and working as intended. I was never able to achieve the goal if firing the script reliably once just using the custom message with the partition hack active in the panel. I ended with a two-part solution. I changed the event conditions and added a test to the virtual device that is set to 0 when the panel is armed. The script when the custom trigger is seen then sets this virtual device to on. So when the custom trigger message is bouncing from one partition to the other the condition won't be true and the script won't re-trigger until I set the virtual device to off. So all is good.
      On a dumb question. You zinged (no worries and I am grateful you take the time) me on my code for my ifs in the for next loop and pointed out a more elegant method. Aside from butcher rick (which I am) is there any real benefit to be gained on a twice and done loop?
      sub main()
      hs.writelog "Alarm Tripped","The Script has been initiated."
      if hs.DeviceValue(566) = 0 then
      	hs.SetDeviceValueByRef 566,1,True  ' we don't want this script to rerun
      	for x = 1 to 2
      		if x = 1 then seconds=60
      		if x = 2 then seconds=30
      		If hs.devicevalue(269) <> 1 then
      			hs.speak "The alarm has detected entry and the siren will activate in less than "& cstr(seconds) & " seconds.",true,"*:*"
      			hs.waitsecs 1
      			hs.speak "Proceed to nearest keypad and enter your code.",true,"*:*"
      			hs.waitsecs 1
      		end if
      			hs.speak "The home's perimeter video system recorded your approach and entry, that recording is now in the cloud.",true,"*:*"
      			hs.waitsecs 1
      		end if
      		if hs.devicevalue(269) <> 1 then
      			hs.speak "Upon siren activation the police will be notified and these recordings will be provided.",true,"*:*"
      			hs.waitsecs 1
      		end if
      	next
      			hs.speak "Siren activation imminent.",true,"*:*"
      		end if
      end if
      hs.writelog "Alarm Tripped","The Script has completed."
      end sub
      And this is the script that runs once the pane;l is disarmed.
      -Rick
      • #18
        Rick,
        you probably don't even need a loop based on what you are doing.
        you could probably just create a function that accepts 'seconds' as an input and then call the routine twice
        dostuff(30)
        dostuff(60)
        sub dostuff(seconds as integer)
        end sub
        Mark
        HS3 Pro 3.0.0.534
