Vista Alarm System Status Unknown
  • Vista Alarm System Status Unknown
    I'm a new user to HS3, coming from Vera.I have HS3 3.0.0.398 on a Windows 10 PC. I've installed the Vista Alarm plugin (3.0.0.15). I have an Ademco Vista 10se panel and a AD2USB (firmware v.2.2a.8.8). The Vista System Status in HS3 device list always shows Unknown. It never changes. The last panel status will change, but not the Vista System Status. I've putty'd into the AD2USB and it's showing the system status. . The instructions for the AD2USB for my panel states the following "For*SE set*the*address*to*31*" which I have done. I changed the device and interface address from 16 to 31 and then I wasn't able to Arm or Disarm the system from HS3. Any ideas why the Vista Alarm System status is always 'Unknown'?
    Welcome to HS and the Vista Alarm plugin forums.
    you definitely need to use address 31 for the interface address and partition 1 device address
    enable debug mode, and post a few hs log entries so I can see what the plugin is doing with the received msgs.
    Mark
    HS3 Pro 3.0.0.534
      Changing the interface and device address to 31 has resolved my problem. Thanks for the quick reply and for your help.
        Grad its working. Enjoy!
        Mark
        HS3 Pro 3.0.0.534
