Running Plugin Remotely
    Test it on a RPi...just type
    mono nameofplugin.exe server=ipofhomeseer server.
    It'll utilize all of the configuration files on the Homeseer box.
    If the plugin is configured to work in windows and linux this should work fine.
    You will see the plugin come up as remote connection in the plugin manager page.
    Should be the same with the AD2USB connection on a remote RPi.
    I have historically tested this to work with X10, UPB, ZWave, Omni Panel plugins.
    - Pete
    Auto mator
    HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono
    6.10.0.104
    HS4 Lite -
