Disable Voice checkbox by default
  • Disable Voice checkbox by default
    It seems that because Google & Alexa won't let you control security devices via their APIs, HS processing of available devices breaks down if presented with a security device that has "Enable Voice" checked.
    Since there's really no point in controlling my glass break sensors, doors, windows or motion sensors by voice would you consider making sure you turn off that bit when adding a new zone device? Probably makes sense for any of the devices created by a security plugin in general...
    its really strange. some my devices have the Voice checkbox checked and some don't. i wonder if different versions of HS3 change that checkbox when the device is created
    i'll make a note to uncheck the box for these devices.
    Mark
    HS3 Pro 3.0.0.534
      Yes the most recent releases of HS3 automatically check this as most users didn't know that it was required to be used with Amazon and Google devices.
      -Rupp
        While I stand by the idea of it being good for security devices to have this off by default, it seems perhaps there was another issue causing the hs/Google integration to break and it was a coincidence that a couple of us found that disabling this checkbox fixed it (when instead it was lucky timing).
