Individual keys
  • Individual keys
    I'm new to homeseer and just trying to figure out this plugin. I got it working and am abale to arm/disarm my alarm.
    However I would like to have control of individual keys. Basically I want a keypad. I can build on in HS3 Designer, but I don't see any way to link the button presses to the numeric keys. All I am seeing are functions suchs as arm away, arm stay, disarm, etc.
    Any way to control individual keys?
    Welcome.
    I haven't done this, but you should be able to use the Send Command event action to send individual numbers
    Mark
    HS3 Pro 3.0.0.534
      Originally posted by mnsandler View Post
      Welcome.
      THanks,
      I will give it a shot.
        Ok, only thing I see here that looks close is: "Run a Script or Script Command".
        When I select that, it asks me for:
        Sub or Function
        and
        Parameters.
        I am a bit lost here. I thought I would see a place to choose the device, and then the individual keys.
          maybe it would be easier to run an event (from within hstouch), and build an event in hs3 that is based on the action i mentioned above
          Mark
          HS3 Pro 3.0.0.534
              george,
              i'm not an hstouch expert but check out the pic below. it should get you pointed in the right direction. The HSTouch forum is probably a better place to get detailed help
              Mark
              HS3 Pro 3.0.0.534
                  right.
                  so create the individual hs events using the vista alarm action send command to send the keystrokes you need to send
                  using the script doesn't save you anything.
                  use the events, they are easier to build and maintain
                  Mark
                  HS3 Pro 3.0.0.534
                    They don’t have actions for the numerical keypad. That’s the problem.
                      can't you build an event like the pic below to send the 1 key
                      you will need other unique events to send the other individual keys
                      i don't know if there is a way to take the button from hstouch and use that as a parameter as input to an event or even a script
                      Mark
                      HS3 Pro 3.0.0.534
                        Now I feel like an idiot. I didn't see the selection for "Vista Alarm Send Command".
                        It works.
                        Thanks for your help!
