HS2 alarm plug in and if-then script help needed
  • HS2 alarm plug in and if-then script help needed
    Hi, I have been trying to figure out how to do this for several hours and need some help. I have the BLSecurity plug in which has been working great for many years!
    I'd like to pulse one of 4 server outputs based on the alarm status, in an if-then script. The output part works. Where I am getting stuck is how to use the SystemStatus with an if-then. I'd like to pulse output 1 if SystemStatus is 1 (i.e. ready) etc.
    Imports HSPI_VISTAALARM
    Sub Main(SystemStatus As Short)
    If SystemStatus = 1 Then
    hs.GetURLIE ("http://root***@192.168.1.71/axis-cgi/io/output.cgi?action=1:/300\",False)
    ElseIf SystemStatus = 2 Then
    hs.GetURLIE ("http://root***@192.168.1.71/axis-cgi/io/output.cgi?action=2:/300\",False)
    ElseIf SystemStatus = 3 Then
    hs.GetURLIE ("http://root***@192.168.1.71/axis-cgi/io/output.cgi?action=3:/300\",False)
    ElseIf SystemStatus = 4 Then
    hs.GetURLIE ("http://root***@192.168.1.71/axis-cgi/io/output.cgi?action=4:/300\",False)
    End If
    End Sub
    you need to use one of the hs.devicevalue() functions to actually get the value of the System Status device
    see the following help page:
    http://help.homeseer.com/help/HS3/st...ch=DeviceValue
    so something like
    if hs.devicevaluebyname("Vista Alarm System Status") then
    where "Vista Alarm" is the location
    Mark
    HS3 Pro 3.0.0.534
      Thank you! This really made my day :-)
      Sub Main(SystemStatus)
      if hs.devicevaluebyname("Vista Alarm System Status") =1 then
      hs.GetURLIE "http://root***@192.168.1.71/axis-cgi/io/output.cgi?action=1:/300\",False
      Elseif hs.devicevaluebyname("Vista Alarm System Status") =2 then
      hs.GetURLIE "http://root***@192.168.1.71/axis-cgi/io/output.cgi?action=2:/300\",False
      Elseif hs.devicevaluebyname("Vista Alarm System Status") =3 then
      hs.GetURLIE "http://root***@192.168.1.71/axis-cgi/io/output.cgi?action=3:/300\",False
      Elseif hs.devicevaluebyname("Vista Alarm System Status") =4 then
      hs.GetURLIE "http://root***@192.168.1.71/axis-cgi/io/output.cgi?action=4:/300\",False
      End If
      End Sub
        you're welcome
        how about something simple like this
        status = hs.devicevaluebyname("Vista Alarm System Status")
        if status >=1 or status <=4 then
        hs.GetURLIE "http://root***@192.168.1.71/axis-cgi/io/output.cgi?action="+Status.tostring+":/300\",False
        end if
        end Sub
        Mark
        HS3 Pro 3.0.0.534
