In the current version of both the Homeseer Mobile app and the Vista module the Vista module when accessed in the mobile app causes the mobile app to close immediately. This can be caused by either the Homeseer Mobile app or the Vista module, so, I am making both sides aware of the problem. By the way HS3 is up to date when I tried the vista module.
Vista module does not work in the Homeseer Mobile app
Originally posted by DesertHound View PostIn the current version of both the Homeseer Mobile app and the Vista module the Vista module when accessed in the mobile app causes the mobile app to close immediately. This can be caused by either the Homeseer Mobile app or the Vista module, so, I am making both sides aware of the problem. By the way HS3 is up to date when I tried the vista module.Mark
HS3 Pro 4.2.19.5
It took me a while, but I was finally able to get most of my Vista devices into HS Mobile. I had to make my controls (disarm, arm, chime, etc.) into events ( if this event is manually triggered then set chime partition 1) and use the event loader in HS Mobile.
I kept getting kicked out of HS Mobile, but I would find an offending device and remove it. Vista did pose a problem as it was at the end of the list of devices to load (alphabetically) and when HS Mobile reaches the end it always seems to close.
If a breathed on it the wrong way (sarcasm) it would also seem to close.
All I can say is keep trying and use events where you can, if you have to.
Hopefully HS Mobile will keep getting better as time goes on.
REK
