How can I tell what connection to choose for Vista alarm plugin?
  • How can I tell what connection to choose for Vista alarm plugin?
    I have a choice of ttyS0 through ttyS3 or ttyUSB0. But none seem to work. How can I eliminate this dimension of the puzzle?
    Currently the plugin starts and logs this:
    Plugin Vista Alarm has connected. IP:127.0.0.1:45216
    It's likely ttyUSB0, as ttyS0 ... ttyS3 are built-in serial ports, not USB ones. To confirm, with the ad2usb device connected, command "ls -l /dev/ttyUSB0", should return something like
    $ ls -l /dev/ttyUSB0
    crw-rw---- 1 root dialout 188, 0 Aug 26 12:31 /dev/ttyUSB0
    Next unplug the device and repeat the command
    ls: cannot access '/dev/ttyUSB0': No such file or directory
      have you tried a general terminal app in linux to test these connections?
      also what plugin version are you running
      Mark
      HS3 Pro 3.0.0.534
        OK. Got the ttyUSB0 to work (I forgot that you had to enable the monitoring, or check the auto-monitor check box). Been a while since I had to set this up...
        A
          Glad you got it working
          Mark
          HS3 Pro 3.0.0.534
