HS3 Vista Alarm plugin v3.0.1.0 Release
This is a sticky topic.
  • HS3 Vista Alarm plugin v3.0.1.0 Release
    The subject version should be in the Updater with a day or two. Please post feedback to this thread
    If you are upgrading, do the following:
    On the Partition and System Status devices change the value of Arm-Away Button to 106
    For Virtual Zone devices with a Fault button, change the Fault Button value to 111
    Changes
    - Allows you to rename the control buttons (Arm-Stay, Arm-Away, etc) after initial setup
    - Supports the !REL (relay) msgs from the AD2USB. See your panel manual for setting these up
    - Register RF devices that aren't programmed into the panel (unassigned)
    - Revised text formatting for Last Panel Message device
    - Added some event Conditions
    - Arm Stay, Arm Instant, and Arm Night Stay will update immediately; doesn't wait for countdown to reach zero
    Fixes since 3.0.0.10
    - the RFX message processing to account for an invalid bit in the message
    - the Vista Alarm config sections on the device edit page
    - saving changes on the Loop and Partition options
    - Telco and comm failure status
    - Bypass zones
    - Bug related to clearing zones at startup
    - Last Panel Message formatting that affected HSTouch
    - Error related to Clearing faulted zones
    - Vista 40 show faults
    Mark
    HS3 Pro 3.0.0.534
    Upon install
    Jan-22 02:24:04 Updater Install/Update of package Vista Alarm failed.
    Jan-22 02:24:04 Updater Error Installation of package Vista Alarm failed. Try disabling the plugin first, then re-try the update.
    Jan-22 02:24:04 Updater Error, package file not found: C:\Program Files\HomeSeer HS3\Updates3\Vista Alarm3.0.1.0\VistaAlarmHelp.htm
    Jan-22 02:24:04 Updater Copying file: C:\Program Files\HomeSeer HS3\html\vistaalarm\VistaAlarmHelp.htm
    Plugin starts OK.
    Appears that the help file is missing from the zip.
      Thanks for the feedback. I'll get this fixed.
      Mark
      HS3 Pro 3.0.0.534
        Originally posted by zwolfpack View Post
        Upon install
        Plugin starts OK.
        please try again. i think I have resolved the missing files. the version is still 3.0.1.0
        Mark
        HS3 Pro 3.0.0.534
          HSPI_VistaAlarm_3.0.1.0b.zip installs successfully. Verified on main system (Windows) and test/demo system (Linux)
            thanks for testing and reporting back.
            Mark
            HS3 Pro 3.0.0.534
              Hi Mark... I recently upgraded... and everything seemed to work. Just noticed in my log that it's VERY busy. took a look and realized I missed this install point:
              I did the first step... but don't see/think I have any virtual zone devices.
              After the steps above, my log is still super busy, just repeating the below over and over every few seconds. What did I miss?
              Apr-11 7:27:54 AM Vista Alarm [1000000100000000----],005,[f70000008005001c08000000000000],"****DISARMED**** READY TO ARM "
              Apr-11 7:27:54 AM Vista Alarm Processing msg on Partition 1
              Apr-11 7:27:54 AM Vista Alarm MessageKey=****DISARMED**** READY TO ARM 1
              Apr-11 7:27:43 AM Vista Alarm [1000000100000000----],005,[f70000008005001c08000000000000],"****DISARMED**** READY TO ARM "
              Apr-11 7:27:43 AM Vista Alarm Processing msg on Partition 1
              Apr-11 7:27:43 AM Vista Alarm MessageKey=****DISARMED**** READY TO ARM 1
              Apr-11 7:27:32 AM Vista Alarm [1000000100000000----],005,[f70000008005001c08000000000000],"****DISARMED**** READY TO ARM "
              Apr-11 7:27:32 AM Vista Alarm Processing msg on Partition 1
              Apr-11 7:27:32 AM Vista Alarm MessageKey=****DISARMED**** READY TO ARM 1
              Apr-11 7:27:21 AM Vista Alarm [1000000100000000----],005,[f70000008005001c08000000000000],"****DISARMED**** READY TO ARM "
              Apr-11 7:27:21 AM Vista Alarm Processing msg on Partition 1
              Apr-11 7:27:21 AM Vista Alarm MessageKey=****DISARMED**** READY TO ARM 1
              Apr-11 7:27:09 AM Vista Alarm [1000000100000000----],005,[f70000008005001c08000000000000],"****DISARMED**** READY TO ARM "
              Apr-11 7:27:09 AM Vista Alarm Processing msg on Partition 1
              Apr-11 7:27:09 AM Vista Alarm MessageKey=****DISARMED**** READY TO ARM 1
              Apr-11 7:27:05 AM Vista Alarm Entering HSEvent
              Apr-11 7:26:58 AM Vista Alarm [1000000100000000----],005,[f70000008005001c08000000000000],"****DISARMED**** READY TO ARM "
              Apr-11 7:26:58 AM Vista Alarm Processing msg on Partition 1
              Apr-11 7:26:58 AM Vista Alarm MessageKey=****DISARMED**** READY TO ARM 1
              Apr-11 7:26:47 AM Vista Alarm [1000000100000000----],005,[f70000008005001c08000000000000],"****DISARMED**** READY TO ARM "
              Apr-11 7:26:47 AM Vista Alarm Processing msg on Partition 1
              Apr-11 7:26:47 AM Vista Alarm MessageKey=****DISARMED**** READY TO ARM 1
              Apr-11 7:26:36 AM Vista Alarm [1000000100000000----],005,[f70000008005001c08000000000000],"****DISARMED**** READY TO ARM "
              Apr-11 7:26:36 AM Vista Alarm Processing msg on Partition 1
              Apr-11 7:26:36 AM Vista Alarm MessageKey=****DISARMED**** READY TO ARM 1
              Apr-11 7:26:25 AM Vista Alarm [1000000100000000----],005,[f70000008005001c08000000000000],"****DISARMED**** READY TO ARM "
              Apr-11 7:26:25 AM Vista Alarm Processing msg on Partition 1
              Apr-11 7:26:25 AM Vista Alarm MessageKey=****DISARMED**** READY TO ARM 1
              Apr-11 7:26:14 AM Vista Alarm [1000000100000000----],005,[f70000008005001c08000000000000],"****DISARMED**** READY TO ARM "
              Apr-11 7:26:14 AM Vista Alarm Processing msg on Partition 1
              Apr-11 7:26:14 AM Vista Alarm MessageKey=****DISARMED**** READY TO ARM 1
              Apr-11 7:26:04 AM Vista Alarm Entering HSEvent
                here's one of the edits. I changed the button.... to I change the other "armed away" status (not at 3) above as well?
Name:	Annotation 2019-04-11 073256.jpg
                  check the option "Suppress duplicate alarm messages" on the plugin settings page, and disable debug mode
                  Mark
                  HS3 Pro 3.0.0.534
                    ah... thanks Mark. Debug mode had turned back on for some reason!
