Vista plugin not initializing after server migration
  • Vista plugin not initializing after server migration
    I recently moved my HS3 instance from one server to a new one following the recommended procedure of copying the HS3 directory from one machine to the new one (after doing a full install on the new machine). Everything works fine including other plug-ins, except the Vista Alarm. It starts and just waits at "Connected, waiting to be initialized...". I've tried disabling, re-enabling, deleting and re-installing the plug-in - all the same. I've also connected to the COM port and can see the A2USB output working fine. The correct COM port is selected as well. Help?
    Did the config/visit alarm.ini make it to the new server?
    If you can get to the config page, enable debug mode and restart
    any errors or in the hs log?
    make sure the plugin monitor device is On
    Mark
    HS3 Pro 3.0.0.534
      Thanks - looked in the logs and saw:
      Warning: The monitor is currently disabled. Turn On device 99 to start the monitor.
      Thats it - thanks so much. Now all works.
        Glad you got it working. thanks for reporting back.
        Mark
        HS3 Pro 3.0.0.534
