Vista 128bpT
  • #16
    I have both the interface address and the single partition set to 18, and I can arm and disarm the system successfully from Homeseer. Just can't get the software to parse the faults (which gets displayed on the panel device in the device list).
    FWIW, I also do not have an emulate LRR checkbox.
    • #17
      Ah, did you create zone devices via the plugin? the plugin needs these hs devices to track the messages from the panel/ad2usb
      Mark
      HS3 Pro 3.0.0.534
      • #18
        I did. The zone devices on my keypad all start with a Z (i.e. Z1, Z2, ..., Z23), but I created all of them matched to the drop-down numbers available. See sample screenshot.
        • #19
          can you redo the previous screen shot and include the hs Address column and display all the devices associated with the plugin
          Mark
          HS3 Pro 3.0.0.534
          • #20
            i saw the full pic. Zone 1 and 2 are updating. is there anything different on the Advanced tab on these devices versas the others? i dont know why the others arent updating
            Mark
            HS3 Pro 3.0.0.534
            • #21
              With debug mode on, please post a fault msg for zone 2 and zone 14. i need to see if they are different somehow
              Mark
              HS3 Pro 3.0.0.534
              • #22
                Jun-07 1:25:19 PM Vista Alarm [00000301100000000A--],002,[f71700040002030028020000000000],"FAULT 002 FRONT GARAGE DOORS "
                Jun-07 1:25:19 PM Vista Alarm Processing msg on Partition 1
                Jun-07 1:25:19 PM Vista Alarm MessageKey=FAULT-2
                Jun-07 1:25:19 PM Vista Alarm Zone changed. Set device Vista Zone 2 to Value=Fault
                Jun-07 1:25:19 PM Vista Alarm Setting System to Faulted
                Jun-07 1:25:19 PM Vista Alarm Setting Partition 1 to Faulted
                Jun-07 1:25:17 PM Vista Alarm [10000001100000003A--],003,[f71700040003001c28020000000000],"****DISARMED**** READY TO ARM "
                Jun-07 1:25:17 PM Vista Alarm Processing msg on Partition 1
                Jun-07 1:25:17 PM Vista Alarm MessageKey=****DISARMED**** READY TO ARM 1
                Jun-07 1:25:17 PM Vista Alarm Setting System to Disarmed-Ready
                Jun-07 1:25:17 PM Vista Alarm Zone changed. Set device Vista Zone 2 to Value=Normal
                Jun-07 1:25:17 PM Vista Alarm Clearing all zones for Ready mode.
                Jun-07 1:25:17 PM Vista Alarm Setting Partition 1 to Disarmed-Ready
                Jun-07 1:25:16 PM Vista Alarm [00000001100000000A--],002,[f71700040002000028020000000000],"FAULT 002 FRONT GARAGE DOORS "
                Jun-07 1:25:16 PM Vista Alarm Processing msg on Partition 1
                Jun-07 1:25:16 PM Vista Alarm MessageKey=FAULT-2
                Jun-07 1:25:14 PM Vista Alarm [00000001100000003A--],002,[f71700040002000c28020000000000],"****DISARMED**** ZONES FAULTED "
                Jun-07 1:25:14 PM Vista Alarm Processing msg on Partition 1
                Jun-07 1:25:14 PM Vista Alarm MessageKey=****DISARMED**** ZONES FAULTED 1
                Jun-07 1:25:14 PM Vista Alarm [00000301100000000A--],002,[f71700040002030028020000000000],"FAULT 002 FRONT GARAGE DOORS "
                Jun-07 1:25:14 PM Vista Alarm MessageKey=FAULT-2
                Jun-07 1:25:14 PM Vista Alarm Zone changed. Set device Vista Zone 2 to Value=Fault
                Jun-07 1:25:13 PM Vista Alarm [00000001100000000A--],003,[f71700040003000028020000000000],"FAULT 003 MUD ROOM MOTION "
                Jun-07 1:25:13 PM Vista Alarm Processing msg on Partition 1
                Jun-07 1:25:13 PM Vista Alarm MessageKey=FAULT-3
                Jun-07 1:25:13 PM Vista Alarm Setting System to Faulted
                Jun-07 1:25:13 PM Vista Alarm Setting Partition 1 to Faulted
                Jun-07 1:25:09 PM Vista Alarm [10000001100000003A--],022,[f71700040022001c28020000000000],"****DISARMED**** READY TO ARM "
                Jun-07 1:25:09 PM Vista Alarm Processing msg on Partition 1
                Jun-07 1:25:09 PM Vista Alarm MessageKey=****DISARMED**** READY TO ARM 1
                Jun-07 1:25:02 PM Vista Alarm [10000001100000003A--],022,[f71700040022001c28020000000000],"****DISARMED**** READY TO ARM "
                Jun-07 1:25:02 PM Vista Alarm Processing msg on Partition 1
                Jun-07 1:25:02 PM Vista Alarm MessageKey=****DISARMED**** READY TO ARM 1
                Jun-07 1:25:02 PM Vista Alarm Setting System to Disarmed-Ready
                Jun-07 1:25:02 PM Vista Alarm Clearing all zones for Ready mode.
                Jun-07 1:25:02 PM Vista Alarm Setting Partition 1 to Disarmed-Ready
                Jun-07 1:24:58 PM Vista Alarm [00000001100000000A--],022,[f71700040022000028020000000000],"FAULT 022 FAMILYROOM MOTION "
                Jun-07 1:24:58 PM Vista Alarm Processing msg on Partition 1
                Jun-07 1:24:58 PM Vista Alarm MessageKey=FAULT-22
                Jun-07 1:24:58 PM Vista Alarm Setting System to Faulted
                Jun-07 1:24:58 PM Vista Alarm Setting Partition 1 to Faulted
                Jun-07 1:24:54 PM Vista Alarm [10000001100000003A--],014,[f71700040014001c28020000000000],"****DISARMED**** READY TO ARM "
                Jun-07 1:24:54 PM Vista Alarm Processing msg on Partition 1
                Jun-07 1:24:54 PM Vista Alarm MessageKey=****DISARMED**** READY TO ARM 1
                Jun-07 1:24:54 PM Vista Alarm Setting System to Disarmed-Ready
                Jun-07 1:24:54 PM Vista Alarm Clearing all zones for Ready mode.
                Jun-07 1:24:54 PM Vista Alarm Setting Partition 1 to Disarmed-Ready
                Jun-07 1:24:52 PM Vista Alarm [00000001100000000A--],014,[f71700040014000028020000000000],"FAULT 014 OFFICEMOTION "
                Jun-07 1:24:52 PM Vista Alarm Processing msg on Partition 1
                Jun-07 1:24:52 PM Vista Alarm MessageKey=FAULT-14
                Jun-07 1:24:52 PM Vista Alarm Setting System to Faulted
                Jun-07 1:24:52 PM Vista Alarm Setting Partition 1 to Faulted
                • #23
                  please review the zones you created. i think created two different entries under Zone 2 (dev 787, 788). this is not supported. the plugin should have prevented this but this maybe causing the problem
                  Mark
                  HS3 Pro 3.0.0.534
                  • #24
                    Ok. I have now deleted the two zones that had duplicates (leaving one device for each of my zones). Should that correct or should I delete the whole thing and rebuild it?
                    • #25
                      NM. I restarted the plugin and it kicked in. It appears to be working! Thank you for all of the help!
                      Jeff.
                      • #26
                        I spoke too soon. Triggers are only available through zone 17, leaving 18-35 off the list. Is there some limit?
                        • #27
                          no limit. the plugin isn't loading 18-35 at startup. enable debug, and restart the plugin and see if there are any errors in the startup log. check the zone 18 device to make sure it looks like the others (see the configuration and advanced tabs)
                          Mark
                          HS3 Pro 3.0.0.534
                          • #28
                            That did it. I deleted 18 (dining room glass break sensor) and the rest loaded. I'm not sure why that's not working, there wasn't a dupe.
                            • #29
                              was there an error in the startup log? if so, can you post it
                              glad you got it working
                              Mark
                              HS3 Pro 3.0.0.534
                              • #30
                                Jun-07 5:02:21 PM Vista Alarm Error: System.ArgumentException: Item has already been added. Key in dictionary: 'Dining Dining Room Glass' Key being added: 'Dining Dining Room Glass' at System.Collections.SortedList.Add (System.Object key, System.Object value) [0x00043] in <3833a6edf2074b959d3dab898627f0ac>:0 at HSPI_VistaAlarm.VistaAlarmClass.LoadZonesSorted () [0x0012b] in :0 [3.0.1.0]
                                Thank you for all the help!
