Roll back to previous version
  • #16
    you should see something like the following when two zones are faulted at the same time. t
    [00000001000000000A--],007,[f70000008007000008000000000000],"FAULT 07 BACK DOOR "
    [00000001000000000A--],020,[f70000008020000008000000000000],"FAULT 20 ZONE 20 "
    Mark
    HS3 Pro 3.0.0.534
    • #17
      Yes everything is showing correctly on the keypad, it cycles through showing all the zones that are faulted. I disabled the plugin and used the alarm decoder virtual keypad and that too was showing the faulted zones as well. I will connect with putty and see if I'm getting something like you posted above.
      • #18
        any chance you have the deduplicate option turned on in the ad2usb firmware settings? that needs to be off or disabled
        Mark
        HS3 Pro 3.0.0.534
        • #19
          That was it! Turned off and is now working correctly.
          THANK YOU!
          • #20
            THANK YOU!
            Well that was easy I wonder how it got enabled (maybe the fw upgrade did it)
            Glad its all working.
            Mark
            HS3 Pro 3.0.0.534
