I am trying to setup vista alarm plugin with a vista 20p, and have a couple of questions. I have 3 keypads with addresses 19, 20, 16. I have the ad2usb configured on the default port 18. I have it connected and it looks like it is talking with the panel, because it pulls three partitions 1, 2, common. Partition 1 is primary house, partition 2 is casita, not sure what partition 3 is. When configuring this on the settings page I enter 18 for my device and pin, on the zones tab initially I entered 18 for all 3 and my pin but later change it to a serial number of a keypad in each zone. what is the correct entry for this page, should it be the serial number for the ad2usb or the actual keypads in the zone?
2nd question is when i have the plugin enabled I am getting a beep noise from my keypads every minute or so, looking at the logs it seems to coincide with the sending of codes. Should it be sending the codes? how do I stop the beeping and get this configured correctly?
Below are the logs from homeseer.
[CODE]
5/3/2020 8:47:08 PM~!~Vista Alarm~!~!Sending.done
5/3/2020 8:47:08 PM~!~Vista Alarm~!~MessageKey=****DISARMED**** Ready to Arm 0
5/3/2020 8:47:08 PM~!~Vista Alarm~!~Ignoring Message
5/3/2020 8:47:08 PM~!~Vista Alarm~!~[1001010100000000----],008,[f70000040008011c08020000000000],"****DISARMED**** Ready to Arm "
5/3/2020 8:47:08 PM~!~Vista Alarm~!~Sending [code]+*3
5/3/2020 8:47:09 PM~!~Vista Alarm~!~Sending *
5/3/2020 8:47:09 PM~!~Vista Alarm~!~Sending [code]+*0
5/3/2020 8:47:09 PM~!~Vista Alarm~!~MessageKey=DISARMED CHIME Hit * for faults 3
5/3/2020 8:47:09 PM~!~Vista Alarm~!~Processing msg on Partition 3
5/3/2020 8:47:09 PM~!~Vista Alarm~!~[0001010110000000----],008,[f70000f71008010c28020000000000]," DISARMED CHIME Hit * for faults"
5/3/2020 8:47:09 PM~!~Vista Alarm~!~!Sending.done
5/3/2020 8:47:09 PM~!~Vista Alarm~!~MessageKey=****DISARMED**** Ready to Arm 0
5/3/2020 8:47:09 PM~!~Vista Alarm~!~Ignoring Message
5/3/2020 8:47:09 PM~!~Vista Alarm~!~[1001010100000000----],008,[f70000040008011c08020000000000],"****DISARMED**** Ready to Arm "
5/3/2020 8:47:09 PM~!~Vista Alarm~!~Setting Partition 3 to Disarmed-Ready
5/3/2020 8:47:09 PM~!~Vista Alarm~!~Clearing all zones for Ready mode.
5/3/2020 8:47:09 PM~!~Vista Alarm~!~MessageKey=DISARMED CHIME Ready to Arm 3
5/3/2020 8:47:09 PM~!~Vista Alarm~!~[1001000110000000----],008,[f70000f31008001c28020000000000]," DISARMED CHIME Ready to Arm "
5/3/2020 8:47:10 PM~!~Vista Alarm~!~!Sending.done
5/3/2020 8:47:10 PM~!~Vista Alarm~!~MessageKey=DISARMED CHIME Ready to Arm 3
5/3/2020 8:47:10 PM~!~Vista Alarm~!~Processing msg on Partition 3
5/3/2020 8:47:10 PM~!~Vista Alarm~!~[1001010110000000----],008,[f70000f71008011c28020000000000]," DISARMED CHIME Ready to Arm "
5/3/2020 8:47:10 PM~!~Vista Alarm~!~MessageKey=****DISARMED**** Ready to Arm 0
5/3/2020 8:47:10 PM~!~Vista Alarm~!~Ignoring Message
5/3/2020 8:47:10 PM~!~Vista Alarm~!~[1001010100000000----],008,[f70000040008011c08020000000000],"****DISARMED**** Ready to Arm "
5/3/2020 8:47:11 PM~!~Vista Alarm~!~MessageKey=ARMED ***AWAY***** ALL SECURE ** 2
5/3/2020 8:47:11 PM~!~Vista Alarm~!~Processing msg on Partition 2
5/3/2020 8:47:11 PM~!~Vista Alarm~!~[0100000100000000----],008,[f70000080008000c0c020000000000],"ARMED ***AWAY***** ALL SECURE **"
5/3/2020 8:47:11 PM~!~Vista Alarm~!~Setting Partition 3 to Faulted
5/3/2020 8:47:11 PM~!~Vista Alarm~!~Sending [code]+*3
5/3/2020 8:47:11 PM~!~Vista Alarm~!~Sending *
5/3/2020 8:47:11 PM~!~Vista Alarm~!~Sending [code]+*0
5/3/2020 8:47:11 PM~!~Vista Alarm~!~MessageKey=DISARMED CHIME Hit * for faults 3
5/3/2020 8:47:11 PM~!~Vista Alarm~!~Processing msg on Partition 3
5/3/2020 8:47:11 PM~!~Vista Alarm~!~[0001000110000000----],008,[f70000f71008000c28020000000000]," DISARMED CHIME Hit * for faults"
5/3/2020 8:47:11 PM~!~Vista Alarm~!~!Sending.done
5/3/2020 8:47:12 PM~!~Vista Alarm~!~!Sending.done
5/3/2020 8:47:12 PM~!~Vista Alarm~!~MessageKey=****DISARMED**** Ready to Arm 0
5/3/2020 8:47:12 PM~!~Vista Alarm~!~Ignoring Message
5/3/2020 8:47:12 PM~!~Vista Alarm~!~[1001010100000000----],008,[f70000040008011c08020000000000],"****DISARMED**** Ready to Arm "
5/3/2020 8:47:12 PM~!~Vista Alarm~!~Sending [code]+*3
5/3/2020 8:47:12 PM~!~Vista Alarm~!~Sending *
5/3/2020 8:47:13 PM~!~Vista Alarm~!~Sending [code]+*0
5/3/2020 8:47:13 PM~!~Vista Alarm~!~MessageKey=DISARMED CHIME Hit * for faults 3
5/3/2020 8:47:13 PM~!~Vista Alarm~!~Processing msg on Partition 3
5/3/2020 8:47:13 PM~!~Vista Alarm~!~[0001010110000000----],008,[f70000f71008010c28020000000000]," DISARMED CHIME Hit * for faults"
5/3/2020 8:47:13 PM~!~Vista Alarm~!~!Sending.done
5/3/2020 8:47:14 PM~!~Vista Alarm~!~!Sending.done
5/3/2020 8:47:14 PM~!~Vista Alarm~!~MessageKey=****DISARMED**** Ready to Arm 0
5/3/2020 8:47:14 PM~!~Vista Alarm~!~Ignoring Message
5/3/2020 8:47:14 PM~!~Vista Alarm~!~[1001010100000000----],008,[f70000040008011c08020000000000],"****DISARMED**** Ready to Arm "
5/3/2020 8:47:14 PM~!~Vista Alarm~!~Setting Partition 3 to Disarmed-Ready
5/3/2020 8:47:14 PM~!~Vista Alarm~!~Clearing all zones for Ready mode.
5/3/2020 8:47:14 PM~!~Vista Alarm~!~MessageKey=DISARMED CHIME Ready to Arm 3
5/3/2020 8:47:14 PM~!~Vista Alarm~!~Processing msg on Partition 3
5/3/2020 8:47:14 PM~!~Vista Alarm~!~[1001000110000000----],008,[f70000f31008001c28020000000000]," DISARMED CHIME Ready to Arm "
5/3/2020 8:47:14 PM~!~Vista Alarm~!~[1001010110000000----],008,[f70000f71008011c28020000000000]," DISARMED CHIME Ready to Arm "
5/3/2020 8:47:16 PM~!~Vista Alarm~!~Setting Partition 3 to Faulted
5/3/2020 8:47:16 PM~!~Vista Alarm~!~Sending [code]+*3
5/3/2020 8:47:16 PM~!~Vista Alarm~!~Sending *
5/3/2020 8:47:16 PM~!~Vista Alarm~!~Sending [code]+*0
5/3/2020 8:47:16 PM~!~Vista Alarm~!~MessageKey=DISARMED CHIME Hit * for faults 3
5/3/2020 8:47:16 PM~!~Vista Alarm~!~Processing msg on Partition 3
5/3/2020 8:47:16 PM~!~Vista Alarm~!~[0001000110000000----],008,[f70000f71008000c28020000000000]," DISARMED CHIME Hit * for faults"
5/3/2020 8:47:16 PM~!~Vista Alarm~!~!Sending.done
5/3/2020 8:47:17 PM~!~Vista Alarm~!~!Sending.done
5/3/2020 8:47:17 PM~!~Vista Alarm~!~MessageKey=****DISARMED**** Ready to Arm 0
5/3/2020 8:47:17 PM~!~Vista Alarm~!~Ignoring Message
5/3/2020 8:47:17 PM~!~Vista Alarm~!~[1001010100000000----],008,[f70000040008011c08020000000000],"****DISARMED**** Ready to Arm "
5/3/2020 8:47:17 PM~!~Vista Alarm~!~Sending [code]+*3
5/3/2020 8:47:17 PM~!~Vista Alarm~!~Sending *
[CODE]
+*0 5/3/2020 8:47:17 PM~!~Vista Alarm~!~MessageKey=DISARMED CHIME Hit * for faults 3 5/3/2020 8:47:17 PM~!~Vista Alarm~!~Processing msg on Partition 3 5/3/2020 8:47:17 PM~!~Vista Alarm~!~[0001010110000000----],008,[f70000f71008010c28020000000000]," DISARMED CHIME Hit * for faults" 5/3/2020 8:47:17 PM~!~Vista Alarm~!~!Sending.done 5/3/2020 8:47:17 PM~!~Vista Alarm~!~!Sending.done 5/3/2020 8:47:18 PM~!~Vista Alarm~!~!Sending.done 5/3/2020 8:47:18 PM~!~Vista Alarm~!~MessageKey=****DISARMED**** Ready to Arm 0 5/3/2020 8:47:18 PM~!~Vista Alarm~!~Ignoring Message 5/3/2020 8:47:18 PM~!~Vista Alarm~!~[1001010100000000----],008,[f70000040008011c08020000000000],"****DISARMED**** Ready to Arm " 5/3/2020 8:47:18 PM~!~Vista Alarm~!~Setting Partition 3 to Disarmed-Ready 5/3/2020 8:47:18 PM~!~Vista Alarm~!~Clearing all zones for Ready mode. 5/3/2020 8:47:18 PM~!~Vista Alarm~!~MessageKey=DISARMED CHIME Ready to Arm 3 5/3/2020 8:47:18 PM~!~Vista Alarm~!~Processing msg on Partition 3 5/3/2020 8:47:18 PM~!~Vista Alarm~!~[1001010110000000----],008,[f70000f71008011c28020000000000]," DISARMED CHIME Ready to Arm " 5/3/2020 8:47:20 PM~!~Plug-In~!~Shutting down Plug-In: Vista Alarm 5/3/2020 8:47:20 PM~!~Info~!~Plugin Vista Alarm with instance: has disconnected
