I'm not sure if this is by design or limitations because of HS4. When I select a device edit of a zone, ex: to rename the zone, once I complete the edit and save, the zone (zone type doesn't matter) does not respond and continues that way forever. If I delete the zone re-add the zone, it's fine.
Something tells me it isn't normal but, I just wanted to shed some light on the operation.
I did search and found examples of this happening not knowing what caused it and re-adding the zone after deletion was the fix.
