Fixes
- Duplicate spaces in messages affecting Message Trigger.
- Monitor can no longer be shutdown via script or event, only via status buttons.
- Default device statuses for new installations.
New Features
- Send Command Action: Send custom commands (such as Btn A, Panic Sequences, etc) to the alarm via an Event Action.
- Test System Action: Sends a Test command to the panel
- Auto start monitor option on Settings page. This will start the monitor even if Device 99 was Off when HS was shutdown.
- Debug mode now puts plus(+) signs in place of spaces in alarm message logged to the HS log. This is for display purposes only. Do not use the + sign in Message Triggers.
Please reply to this message with issues and bugs
Installation Instructions:
You may install this new version over any existing version. The old version will be uninstalled.
Note for Vista users: I have attempted to make this install package compatible with Windows Vista, but can't test it. If you receive an error installing this package, try the following:
1. right click on a CMD icon and select run as Administrator
2. Enter msiexec /i HomeSeerPluginVistaAlarm_1_1_0_0.msi (note: you will need to be in the directory where the msi file exists to run this.)
Enjoy!
New Features
Enjoy!
