A few changes in this version from v1.2.10:
- Restored standard com port access for the AD2Serial board
- Added custom values/graphics to RF Devices
- Defaulted the port disconnect checking to 1 minute, you can increase this if you are getting false disconnects (during programming mode, for example). See the PortPollInterval setting below:
- Fixed Arm Maximum event action (1.2.14.1)
- Fixed error when clearing zones (1.2.14.1)
If you are using an AD2USB and having disconnect issues, please do the following before starting HS:
1. Add the following bolded entry to the vistaalarm.ini
[AD2USB]
InterfaceType=USB
Add this setting if you are getting false disconnects. 1 (min) is default. Increase as necessary.
[General]
PortPollInterval=2
2. Installation
Installation for existing users:
- shutdown HS
- Back up your current HS folder
- You must copy both dll files from the zip into your homeseer folder even if you are only using an AD2Serial otherwise you will get errors on startup.
- Restart HS
Installation for new users:
- Install the current version in the Updater and then follow the above installation
3. Create an event to notify you of a disconnect using the Vista Alarm Interface Trigger Disconnected option. this way you will know when the plugin tries to recover the usb port.
Please report your finders, and perferably post a debug log
[AD2USB]
InterfaceType=USB
[General]
PortPollInterval=2
2. Installation
- shutdown HS
- Restart HS
