I have an AD2USB, Version 1.2.0.0 of the plugin, and have configured it according to the plugin documentation, set up a non-master account, and put in that code on my one and only partition since the documentation states that if I have a 50 panel I have to use a non-master user code. I used my master code in the main settings page per the plugin documentation.
I have been able to add all the zones, and HS can read the status. I'm using door sensors to turn on certain lights, for instance. However, when I try to arm/disarm the alarm nothing happens. The log says " Vista Alarm - Sending [code]+3" and then nothing happens.
I've gone over the documentation for this plugin and the alarm system again and again and I can't figure out what I'm doing wrong. I suspect that I'm very close, but i would like to be able to automate arming and disarming the alarm system and just can't seem to be able to crack it. Does anyone know what the trick is here?
