Just bought the plugin (should have tested it first I suppose) and I'm having issues getting it to talk to the ad2serial I have installed in my 21p panel.
I can communicate through putty on COM1 at 19200 n81 just fine with the ad2serial device and issue commands and see responses through it, but when I set it to COM1 in the HS ad2 plugin, it fails to communicate with the device (I closed my terminal program as well before launching HS).
Is it attempting to communicate using 115200? Can this be specified anywhere? The docs specifically say "The AD2SERIAL Adapter operates at a different baud rate (19200,8,n,1).
I'll keep digging but any help would be appreciated.
FYI I also installed the beta, and the same thing happened.
