HS3 Vista Alarm plugin v3.0.0.10 Release
  • #46
    It's a zwave Wayne dalton -- but on research just found it's actually a driver issue
    Problem fixed by upgrading zwave controller driver to current beta version
    • #47
      So is this purchasable? I bought your HS2 version (which is great!) - is it possible to get an upgrade price?
      • #48
        yes, it's avail on the following page at a 50% discount for hs2 users. you'll need your hs2 license code
        http://store.homeseer.com/store/Search.aspx?m=56
        Mark
        HS3 Pro 3.0.0.534
        • #49
          Cool. I bought it but it doesn't seem to work.
          I have a A2SERIAL on COM1 (works fine in HS2), but when I go into HS3 (HS2 is not running):
          /1/2014 4:00:32 PM ~!~Vista Alarm~!~Loading the Partitions
          5/1/2014 4:00:33 PM ~!~Vista Alarm~!~Opened COM port 1
          5/1/2014 4:00:33 PM ~!~Vista Alarm~!~Sent cmd: V
          5/1/2014 4:01:32 PM ~!~Plug-In~!~Finished initializing plug-in Vista Alarm
          and then when I go to Plugins->Manage:
          **FATAL**: Failed getting InterfaceStatus from Vista Alarm - the interface was not found in the list of active interfaces.
          Looks like its not able to communicate with my A2SERIAL. Is it smart enough to set baud to 19200 instead of 115200 used with A2USB?
          • #50
            The AD2Serial requires one additional manual configuration:
            Please added the following to the [General] section of the vistaalarm.ini
            baudrate=19200
            Mark
            HS3 Pro 3.0.0.534
            • #51
              baudrate=19200
              Yup, that did it. Forgot about that step (been a while since I installed your HS2 plugin). Thanks much!
              • #52
                Actually, I do have one final question. I'm migrating my alarm scripts over from HS2, and realize there are significant changes here.
                My issue is that I'm trying to do:
                	Dim VA As Object = hs.plugin("Vista Alarm")
                and its causing an error when I try to run a function that contains that line. Is this not the proper way to fetch a reference to the Vista Alarm plugin now? (Likely a noob question - I'm just starting to dive into HS3 framework now)
                • #53
                  Oh, they changed everything regarding plugin functions via scripts
                  check out pluginfunction in the online help
                  http://homeseer.com/support/homeseer...lp/default.htm
                  you'll have to recode most of the scripts
                  Mark
                  HS3 Pro 3.0.0.534
                  • #54
                    Fault will not clear
                    Hi just loaded the 3.0.0.10 version everything is looking good but when I added a zone when fault will not clear and one have this issue ?
                    almost looks like the plugin is not getting updated but arm and disarm work just fine any ideas ?
                    • #55
                      so if you manually fault the zone and then clear it, the plugin isn't getting updated?
                      does the device address match the actual zone number?
                      what type of zone is it? door/window sensor or keyfab,etc
                      Mark
                      HS3 Pro 3.0.0.534
                      • #56
                        Fault
                        That is correct on the alarm panel the shows no fault yes they match each zone on the alarm motion and door sensors no errors in the logs.
                        • #57
                          are you having this problem with other zones in the same partition?
                          are these zones in a different partition?
                          if not, can you delete these zones from the plugin and re-add and retest
                          Mark
                          HS3 Pro 3.0.0.534
                          • #58
                            Where are you looking to see if it clears or not? the web page or via HStouch client. I ask cause I know there has been issues with different hstouch clients not updating status properly
                            • #59
                              Thanks for the help
                              I deleted and reloaded the plug in everything works like a champ!
                              • #60
                                strange. I wish i knew what caused these problems. glad its working.
                                Mark
                                HS3 Pro 3.0.0.534
