Telco Failure Device (1=Dim)
  • Telco Failure Device (1=Dim)
    Hi,
    Any idea why the plugin would set the Telco Failure device to anything other than On (100) or Off (0)?
    I had it trigger by a power outage and when power was restored, it never went away and I started getting image failures in HStouch because I was matching replacement images based on the status.
    Any thoughts on this?
    no idea. can you review your log and see if you can find when it was set to 1
    you may need to review the log history in the hs database. i think there are plugins to do this
    Mark
    HS3 Pro 3.0.0.534
      Yeah, I can look. Any idea how to set it back?
        can you manually disconnect the telco from the panel and see how the plugin responds? disconnecting and reconnecting the line should reset it
        Mark
        HS3 Pro 3.0.0.534
          I got "telco failure" this morning after I reset the system day before yesterday. Now it shows as on.
          A few days ago I unplugged the telephone cable and plugged av analog line in and I got a dial tone but then I got the COMM. FAILURE notice and had to force an alarm to clear the error.
          When I unplugged the cable a couple days ago it didn't do anything since the virtual device was already in an on state (how it currently is now)
            with debug mode enabled, can you post a log snippet when you disconnect the telcon, let the panel respond and then reconnect telco
            Mark
            HS3 Pro 3.0.0.534
              Sorry I haven't had a chance to do this yet, I had another Telco failure where the device turned on. Now it is back to dim=1. I'll look through the logs this evening
              What plugin helps with the search
                This is what I get when I search for telco failure. I am assuming you are looking for details. I have to put it in Debug mode and cause a failure (newborn) hopefully I will have some time tomorrow
                  i think there a blade plugin BL{something}
                  Mark
                  HS3 Pro 3.0.0.534
                    So I enabled debug and unplugged
                    here are the logs
                    I didn't see any device control events during this time and no matter what I did the device value still shows as 1 dim.
                    Strange
                      the plugin is not processing the telco msg. what vista panel model # do you have?
                      Mark
                      HS3 Pro 3.0.0.534
                        Vista 20p
                          I believe this used to work at some point in time. but my phone line hadn't gone down over a year so its hard to tell.
                          Any thoughts on what to do to resolve/test?
                            this is very strange. what plugin version are you running?
                            i'll have to add some additional debug msgs to determine what' going on
                            Mark
                            HS3 Pro 3.0.0.534
                              Yeah, i totally agree. I am running 3.0.0.15
