Telco Failure Device (1=Dim)
  • #16
    i found the issue. i'll post an new version here once i fix it.
    Mark
    HS3 Pro 3.0.0.534
    • #17
      Nice work! Thanks as always for your responsive support.
      • #18
        Wow, i can't believe anyone else ran into this problem sooner.
        can you please test the following while you are testing the telco fault issue:
        - pull the ac power and check the device status, and then reconnect ac and recheck
        - disconnect the battery and check the device status, and then reconnect the battery and check the device status
        thanks
        to install, just shutdown hs3, replace the existing vistaalarm exe with the one in the zip, then restart hs3
        Mark
        HS3 Pro 3.0.0.534
        • #19
          I installed the plugin, I am assuming that I need to initiate a telco failure for the plugin to interpret. I can do that tomorrow for sure. I will also test the other two (battery and AC) at the same time.
          Thanks for the quick Turnaround on this and I am glad to see another bug bite the dust.
          • #20
            you could try faulting a zone and then clearing it, but i think you will need to disconnect and reconnect
            Mark
            HS3 Pro 3.0.0.534
            • #21
              please also arm the panel while you are getting the telco faults and see how the plugin responds.
              Mark
              HS3 Pro 3.0.0.534
              • #22
                So I did some testing with the new version
                Both the "System Low Battery" and the "Telco Failure" device triggered to On when the respective condition arose.
                The AC Power Loss Device never triggered. I verified that the panel recognized the event by checking the last panel message.
                I am still waiting for the Telco and Battery Low fault to clear from the panel so I can verify that they have properly reset.
                • #23
                  can you post a debug log of the ad2usb msgs showing the ac loss
                  Mark
                  HS3 Pro 3.0.0.534
                  • #24
                    Ok, i'll email you the log since it may contain alarm codes. What is your email address?
                    BTW, Everything Reset properly.
                    • #25
                      all i need is an log entry like the following. there are no panel codes embedded.
                      [10000001000000003A--],000,[f70000008000001c08000000000000],"****DISARMED**** READY TO ARM "
                      Mark
                      HS3 Pro 3.0.0.534
                      • #26
                        I cleared out the codes
                        sorry it is a big log. It has all of the testing done this morning including troubleshooting a Comm. Failure with my monitoring company
                        • #27
                          This is probably what you are looking for
                          [0000000000000000----],008,[f70000051008000c00020000000000],"AC LOSS "
                          • #28
                            Might not be a bad idea to add a device for the Comm. Failure
                            [0001000100000000----],0fc,[f700000510fc000008020000000000],"COMM. FAILURE "
                            • #29
                              in hs2 i had this msg trip the Telco Failure device. I'll get this working in HS3.
                              Mark
                              HS3 Pro 3.0.0.534
                              • #30
                                Nice, thanks!
