i found the issue. i'll post an new version here once i fix it.
Telco Failure Device (1=Dim)
Mark
HS3 Pro 4.2.19.5
Wow, i can't believe anyone else ran into this problem sooner.
can you please test the following while you are testing the telco fault issue:
- pull the ac power and check the device status, and then reconnect ac and recheck
- disconnect the battery and check the device status, and then reconnect the battery and check the device status
thanks
to install, just shutdown hs3, replace the existing vistaalarm exe with the one in the zip, then restart hs3Attached FilesMark
HS3 Pro 4.2.19.5
I installed the plugin, I am assuming that I need to initiate a telco failure for the plugin to interpret. I can do that tomorrow for sure. I will also test the other two (battery and AC) at the same time.
Thanks for the quick Turnaround on this and I am glad to see another bug bite the dust.
Originally posted by skarragallagher View PostI installed the plugin, I am assuming that I need to initiate a telco failure for the plugin to interpret. I can do that tomorrow for sure. I will also test the other two (battery and AC) at the same time.
Thanks for the quick Turnaround on this and I am glad to see another bug bite the dust.Mark
HS3 Pro 4.2.19.5
please also arm the panel while you are getting the telco faults and see how the plugin responds.Mark
HS3 Pro 4.2.19.5
So I did some testing with the new version
Both the "System Low Battery" and the "Telco Failure" device triggered to On when the respective condition arose.
The AC Power Loss Device never triggered. I verified that the panel recognized the event by checking the last panel message.
I am still waiting for the Telco and Battery Low fault to clear from the panel so I can verify that they have properly reset.
Originally posted by skarragallagher View PostSo I did some testing with the new version
I am still waiting for the Telco and Battery Low fault to clear from the panel so I can verify that they have properly reset.Mark
HS3 Pro 4.2.19.5
Originally posted by skarragallagher View PostOk, i'll email you the log since it may contain alarm codes. What is your email address?
BTW, Everything Reset properly.
[10000001000000003A--],000,[f70000008000001c08000000000000],"****DISARMED**** READY TO ARM "Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postall i need is an log entry like the following. there are no panel codes embedded.
sorry it is a big log. It has all of the testing done this morning including troubleshooting a Comm. Failure with my monitoring companyAttached Files
Originally posted by skarragallagher View PostMight not be a bad idea to add a device for the Comm. Failure
[0001000100000000----],0fc,[f700000510fc000008020000000000],"COMM. FAILURE "Mark
HS3 Pro 4.2.19.5
