"Last Panel Message" changing column width in devices view
  • "Last Panel Message" changing column width in devices view
    Just getting a new Vista 20 panel going and all is working well except as my panel bounces back and forth between "disarmed" and "low battery" it causes the devices page to shift back and forth every 2 seconds.
    Is there any way to prevent this? I don't want to delete the device, I use the text string for a text message when the alarm goes off.
    thanks,
    Dan
    PS - yes I know I should replace my battery
    just hide the hs device for now
    Mark
    HS3 Pro 3.0.0.534
      thanks, Mark - I should have mentioned, I tried hiding the device but it won't "take". I tried it a few times and it won't hide. I check the box for the device then select hide but it stays.
      not sure if that's a plugin specific thing or a more general HS3 thing. I'll try hiding some other devices tonight to see if I get the same behavior.
      thanks,
      Dan
        hiding devices is an hs3 thing. try restarting hs3 and see if it hides
        Mark
        HS3 Pro 3.0.0.534
