another version to test
Trouble in message reading from AD2USB under check and bypass situations
Mark
HS3 Pro 4.2.19.5
one more try. i tested this with three different zones in a variety of states (including putting a 'check' zone into bypass) and everything seems to following correctly.
if you find different results, please list the steps to reproduce the issue, and include the associated debug log snippet of the steps.
for the record, i'm testing this on a vista 20se which is a little different than a 20p, but i'm pretty sure the panel msgs are encoded the same. this is why i would like to see a log snippet if you find an issue so i can compare.
thanks for testing and reporting backAttached FilesMark
HS3 Pro 4.2.19.5
Phil,
i don't think .21 is the answer. when the chime is enabled, things aren't quite rightMark
HS3 Pro 4.2.19.5
i think I'm going to have to take more drastic measures to resolve this. i even found a scenario when zones 6 & 7 were faulted, and i tried to bypass zone 7, that the plugin would bypass zone 6 based on the msg received from the panel.Mark
HS3 Pro 4.2.19.5
Originally posted by pciccone View PostI'm a patient guy. I am surprised no other users of your plugin ever reported this. I know you have a strong base of followers already
The plugin typically only processes the byte data in the panel messages to interpret what is going on with each msg; I've tried to avoid parsing the alpha messages because I'm not sure they are consistent between panel models and languages.
Nevertheless, there doesn't seem to be any way around this Bypass issue. The Byte data just doesn't consistently identify a Bypass zone event.
.22 looks specifically for the BYPAS XX alpha msg before it sets a zone to Bypass. this seems to work consistently. that said, i have found that if i fault another zone immediately after using Bypass, the BYPAS msg may never show. There is nothing i can do about this scenario.
let me know what you find.Attached FilesMark
HS3 Pro 4.2.19.5
I understand what you are saying. We use bypass because we have a pet door that we keep open for the dogs, that is on the alarm. So we bypass it unless we lock the dogs in, and go away for an extended period. The door is so large, a human can enter through it.
We also bypass when we have spring and fall, using the whole house fan. We bypass windows that are open. We have a big house, lots of zones (I think about 30+)
I just put .22 in, will let you know.
any feedback on .22?Mark
HS3 Pro 4.2.19.5
thanks for the feedback. i did a little testing on the "check" scenario but i only tested one zone in 'check' status. i was able to bypass it successfully without affecting the other zones.
thanks for hanging in there with this.Mark
HS3 Pro 4.2.19.5
Phil, thanks for the follow up. I'll consider this good. and post this version as the latest productionMark
HS3 Pro 4.2.19.5
