Which User Armed/Disarmed
  • Which User Armed/Disarmed
    We recently install a Vista 20P alarm system at work with an AD2USB interface. I installed version the plugin version 3.0.0.15 and then upgraded to the BETA 3.0.0.22. (I am running HS3 v 3.0.0.208). I see status messages in the log and I can trigger events based on partition status. No errors that I can see.
    What I haven't been able to figure out is determining which user has armed or disarmed the partition. I see nothing in the log that would indicate a user. In the plugin setup, I enabled 'Emulate LRR'. As I understand it, LRR is really just a cell phone module, which our alarm monitoring company uses to monitor our system. (Is this correct?)
    Apparently this portion works because the app that the alarm company provides shows who armed/disarmed and at what times. I wrote several events to simply send me an e-mail when the alarm is armed or disarmed by user n ('n' being user 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15 or 16). The alarm company programmed these users. I didn't see anything in the plugin setup regarding users.
    I must be missing something basic in the setup. Any ideas?
    - Robert
    There is a Vista Alarm User Trigger that you can use to define the user # and partition # to fire an event. You don't need to identify user numbers to the plugin directly.
    Mark
    HS3 Pro 3.0.0.534
      I think that's what I am doing. Here's one of my events:
      - Robert
        so is the event not firing?
        can you enabled debug mode and test and post a log snippet
        Mark
        HS3 Pro 3.0.0.534
          so is the event not firing?can you enabled debug mode and test and post a log snippet
          Correct. The event does not fire. I had set debugging mode already so here's last night's arming entry: (The user that armed it was user #13 and that event didn't fire either).
          Feb-17 7:30:41 PM Vista Alarm [0101000100000000----],059,[f70400ff105900000c020000000000],"ARMED ***AWAY***May Exit Now 59"
          Feb-17 7:30:41 PM Vista Alarm Processing msg on Partition 1
          Feb-17 7:30:41 PM Vista Alarm MessageKey=ARMED ***AWAY***May Exit Now 59 1
          Feb-17 7:30:40 PM Vista Alarm [0101020100000000----],060,[f70400ff106002000c020000000000],"ARMED ***AWAY***May Exit Now 60"
          Feb-17 7:30:40 PM Vista Alarm Processing msg on Partition 1
          Feb-17 7:30:40 PM Vista Alarm MessageKey=ARMED ***AWAY***May Exit Now 60 1
          Feb-17 7:30:40 PM Vista Alarm Setting System to Armed Away
          Feb-17 7:30:40 PM Vista Alarm Setting Partition 1 to Armed Away
          Feb-17 7:30:36 PM Vista Alarm [1001000100000000----],008,[f70400ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
          Feb-17 7:30:36 PM Vista Alarm Processing msg on Partition 1
          Feb-17 7:30:36 PM Vista Alarm MessageKey=****DISARMED**** Ready to Arm 1
          - Robert
            so there should be !LLR msgs logged.
            can you turn the vista monitor (device vista 1) off, and on, and post the msgs generated. Just want to verify your ad2usb supports LLR.
            also change the LLR setting Off (click save) and On (click save), and post those log msgs. I need to see if the setting is getting to the ad2usb
            Mark
            HS3 Pro 3.0.0.534
              Ok, Here's the log:
              Feb-18 7:53:06 AM Vista Alarm Monitor started...
              Feb-18 7:53:06 AM Vista Alarm Loading RF Devices...
              Feb-18 7:53:06 AM Vista Alarm Found the AD2USB on port COM6 running firmware version V2.2a.6
              Feb-18 7:53:06 AM Vista Alarm Received msg: !VER:ffffffff,V2.2a.6,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR ;KE;MK;CB
              Feb-18 7:53:06 AM Vista Alarm Sent cmd: V
              Feb-18 7:53:06 AM Vista Alarm Opened COM port COM6
              Feb-18 7:53:06 AM Device Control Device: Vista Alarm Vista Alarm Monitor Status to On (100) by/from: CAPI Control Handler
              Feb-18 7:53:00 AM weatherXML Check timer items
              Feb-18 7:53:00 AM Vista Alarm Monitor terminated...
              Feb-18 7:53:00 AM Vista Alarm Closed COM port COM6
              Feb-18 7:53:00 AM Device Control Device: Vista Alarm Vista Alarm Monitor Status to Off (0) by/from: CAPI Control Handler
              - Robert
                and here's the log for the LRR on/off:
                Feb-18 8:10:11 AM Vista Alarm !CONFIG>ADDRESS=18&CONFIGBITS=ff00&LRR=Y&EXP=NNNNN&REL=NNNN& MASK=ffffffff&DEDUPLICATE=N
                Feb-18 8:10:11 AM Vista Alarm !setting LRR emulation ON
                Feb-18 8:10:11 AM Vista Alarm !setting ADDRESS 18
                Feb-18 8:10:11 AM Vista Alarm !>ADDRESS=18&LRR=Y
                Feb-18 8:10:11 AM Vista Alarm Updating the configuration on the interface...
                Feb-18 8:10:11 AM Vista Alarm Settings page submitted
                Feb-18 8:10:03 AM Vista Alarm !CONFIG>ADDRESS=18&CONFIGBITS=ff00&LRR=N&EXP=NNNNN&REL=NNNN& MASK=ffffffff&DEDUPLICATE=N
                Feb-18 8:10:02 AM Vista Alarm !setting LRR emulation OFF
                Feb-18 8:10:02 AM Vista Alarm !setting ADDRESS 18
                Feb-18 8:10:02 AM Vista Alarm !>ADDRESS=18&LRR=N
                Feb-18 8:10:02 AM Vista Alarm Updating the configuration on the interface...
                Feb-18 8:10:02 AM Vista Alarm Settings page submitted
                - Robert
                  ok. thanks. that all looks good. please reenable the emulate llr option and retest the arm/disarm
                  Mark
                  HS3 Pro 3.0.0.534
                    Oh. i almost forgot, you need to enable the LRR feature on your panel as well. on a 20p its field *29
                    Mark
                    HS3 Pro 3.0.0.534
                      Ok, the alarm guy is coming today to check on a few things so I'll have him do that and let you know how it goes. Thanks.
                      - Robert
                        if you can get the installer code from him, i would. might be helpful in the future.
                        for reference, if you disable the LRR feature in the plugin/ad2usb, and the LRR is enabled in the panel, the panel will complain.
                        Mark
                        HS3 Pro 3.0.0.534
                          Just talked with him. He gave me the installer code and said that LRR is already enabled and that's what they use to monitor us.
                          - Robert
                            - Robert
                            if you actually have an LRR module, i wonder what this does to the ad2usb emulator.
                            I'm going to email nutech.com and ask. stay tuned.
                            Mark
                            HS3 Pro 3.0.0.534
                              Ok. since you physically have an LRR module, disable Emulate LRR in the plugin.
                              you will need to program panel fields *65 and *66 to enable the reporting of arm/disarm events
                              Mark
                              HS3 Pro 3.0.0.534
