Comm problem with Vista 10
  • Comm problem with Vista 10
    I've been using this plugin on my HS2 for about 5 years now and it has been rock solid without any issues whatsoever.
    Today, I tried your plugin in HS3 and tried to configure it to work. I couldn't get it to communicate with the panel. So I went back to HS2 thinking perhaps there was something I didn't setup right. Now I can't get it to work with HS2 anymore.
    I have logging enabled, but it seems like it is totally brain dead.
    As can be seen in the startup, there doesn't appear to be any problems with the comm to the AD2USB. The green led is flashing like it's communicating.
    25/02/2016 5:57:52 PM Plug-In Initializing Plug-in: Vista Alarm on COM port 7
    25/02/2016 5:57:52 PM Vista Alarm Opened COM port 7
    25/02/2016 5:57:52 PM Vista Alarm Sent cmd: V
    25/02/2016 5:57:52 PM Vista Alarm Found the AD2USB on COM port 7 running firmware version V2.2a.4
    25/02/2016 5:57:52 PM Vista Alarm Monitor started...
    I can arm manually at the alarm pad but was wondering if when I tried to configure the plugin in HS3 whether or not I put in the wrong password or tried to configure the partition incorrectly.
    Any help would be greatly appreciated.
    Robert
    did you enter a user code on the config page, and create a partition?
    please post pics of the various config pages
    Mark
    HS3 Pro 3.0.0.534
      I power reset the panel and plugin which resolved the issue.
      Thanks.
        glad you got it working
        Mark
        HS3 Pro 3.0.0.534
