Vista 21iP - Armed-away changes to Armed-stay at end of exit delay +solution
  • Vista 21iP - Armed-away changes to Armed-stay at end of exit delay +solution
    Posting this since it seems like it might be a common issue. When setting armed-away thru the the plugin, I noticed that at the end of the exit delay, it would switch to armed-stay. Also found this same behaviour when arming from the panel. This was confusing since I had never seen this before. Found explanation and solution here:
    http://www.doityourself.com/forum/el...xit-delay.html
    Reason I had never seen this was that I always open a door to leave after setting armed-away from the panel!
    Factory default for *84 is 3. Setting to 0 solved my issue.
