Sending Message via script fails
  • Sending Message via script fails
    Hi!
    Firstly great plugin! I've got this working nicely in terms of receiving messages and performing actions.
    I can send reply's using the send message action ok but can't send messages from scripts. I've tried both from within a script and from an event.
    Please see output below from logs. From what I could see from debugging the script it was failing on this line: plugin.PluginFunction("SendMessage", {s1(0), s1(1)})
    Any help would be much appreciated.
    Chris
    Sep-07 6:11:59 PM Error Compiling script /HomeSeer/scripts/BBMessenger.vb: http://mono-project.com/Bugs)
    Sep-07 6:11:59 PM Error Compiling script /HomeSeer/scripts/BBMessenger.vb: Variable declaration without an 'As' clause; Object type assumed.
    Sep-07 6:11:59 PM Error Compiling script /HomeSeer/scripts/BBMessenger.vb: The import 'System.Core' could not be found.
    Sep-07 6:11:51 PM Event Running script in background: /HomeSeer/scripts/BBMessenger.vb("Main","example@public.talk.google.com|Testin g")
    What operating system are you running?
    Originally posted by djmilez View Post
    Hi!
    Chris
      Reading this thread https://forums.homeseer.com/showthread.php?t=175822
      Try this, add Imports System.Core to the beginning of BBMessenger.vb file
      -----new script file----
      Imports System.Core
      'BBMessenger example script on how to send a message via script
      Public Sub Main(ByVal Parms As Object)
      Dim logto As String = "BBMessenger-Script"
      hs.WriteLog(logto, "Running script")
      hs.WriteLog(logto, "Sending Message: " + Parms.ToString())
      Dim plugin = New HomeSeerAPI.PluginAccess(hs, "BBMessenger", "")
      Dim s1 As String() = Parms.ToString().Split("|".ToCharArray())
      If (s1.Length >= 2) Then
      If plugin IsNot Nothing Then
      Else
      hs.WriteLog(logto, "Error sending message. Not able to locate the plug-in.")
      End If
      End If
      hs.WriteLog(logto, "Exiting script")
      End Sub
      -----end new script file----
      Hi!
      Chris
        I did try that before and also came across that thread. But same still unfortunately. Running on Rasp Pi details below.
        HomeSeer Version: HS3 Standard Edition 3.0.0.313
        Linux version: Linux raspberrypi 4.4.48-v7+ #964 SMP Mon Feb 13 16:57:51 GMT 2017 armv7l GNU/Linux System
          Seems New Object is required on Linux.
          https://forums.homeseer.com/showthread.php?t=188645
          I tried:
          plugin.PluginFunction("SendMessage", New Object {s1(0), s1(1)})
          But getting other errors now.
          Compiling script /HomeSeer/scripts/BBMessenger.vb: 'End Namespace' must be preceded by a matching 'Namespace'.
          Sep-08 1:47:53 PM Error Compiling script /HomeSeer/scripts/BBMessenger.vb: Identifier expected.
          Sep-08 1:47:53 PM Error Compiling script /HomeSeer/scripts/BBMessenger.vb: Expected 'End'.
          Sep-08 1:47:53 PM Error Compiling script /HomeSeer/scripts/BBMessenger.vb: Expected ')'.
            My raspberry pi died. I am trying with QEMU windows emulation. I will try to pick up a raspberry pi 3 tomorrow.
            Bruce
            I tried:
              I am able to replicate the issue on Debian 9. I think it is a HomeSeer issue, I am going to log a support case with HomeSeer.
              Updated script below to fix the object compile error. With this fix now I am getting Error: Compiling script /home/brbjr/HomeSeer/scripts/BBMessenger.vb: http://mono-project.com/Bugs)
              Sep-09 5:20:30 PM Error Compiling script /home/brbjr/HomeSeer/scripts/BBMessenger.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
              --script--
              Dim plugin As HomeSeerAPI.PluginAccess = New HomeSeerAPI.PluginAccess(hs, "BBMessenger", "")
              Else
              End If
              End If
              End Sub
              --end script ---
              Hi!
              Chris
                Thanks Bruce, i've tried with the changes to see if any different on Rasp Pi and it gives The import 'System.Core' could not be found, same still if I try and import this at the top.
                Will definitely be purchasing this plugin if I can get this resolved, got it working nicely in a script to receive messages and control devices and events, just need to be able to reply with a status.
                Cheers
                Chris
                  Chris,
                  I found a fix in the script syntax, mono is very picky . I pushed a update to the HS Store but it will not overwrite the BBMessenger.vb file, you need to manually update the file with the script below.
                  '---BBmessenger.vb script-----------
                  Dim message(1) As Object
                  message(0) = s1(0)
                  message(1) = s1(1)
                  plugin.PluginFunction("SendMessage", message)
                  Else
                  End If
                  End If
                  End Sub
                  '---End BBmessenger.vb script-----------
                  Bruce
                  Cheers
                  Chris
                    Excellent that's sorted, thanks for resolving so quickly.
                    Is there any way to send images in messages? No worries if not just would be nice addition. But can always send a link to image instead.
                      I researched sending pictures/files via XMPP messages in the past and determined that you have to reference a hosted url in the message.
                      Bruce
