Was working the other day, not working today
    HI, weird problem here.
    HS Pro 3, had BLEmail working to login to my WOW email account every 28 days to keep them from deleting it (I rarely use it but like having it for dealing with them) and today the plugin won't load properly. I get a PENDING, then I get a CRITICAL fail.
    Of course I tried c losing and restarting the PI.... then I rebooted HS itself.... no effect.
    So I uninstalled and reinstalled the PI and no change.
    Here's the filtered log since the uninstall and reinstall. any ideas?
    Oct-29 20:37:31 BLEmail start BLEmail version is: 2.0.10.0
    Oct-29 20:37:31 BLEmail start Initializing BLEmail...
    Oct-29 20:37:31 Starting Plug-In Initializing plugin BLEmail ...
    Oct-29 20:37:30 Starting Plug-In BLEmail loaded in 15005 milliseconds
    Oct-29 20:37:16 Info Plugin BLEmail has connected. IP:127.0.0.1:62342
    Oct-29 20:37:15 Warning I/O interface BLEmail is down, executable is not running, restarting ...
    Oct-29 20:36:49 Info Plugin BLEmail with instance: has disconnected
    Oct-29 20:36:47 Starting Plug-In Plugin BLEmail started successfully in 2045 milliseconds
    Oct-29 20:36:47 BLEmail start BLEmail plugin has been initialized
    Oct-29 20:36:45 BLEmail start BLEmail version is: 2.0.10.0
    Oct-29 20:36:45 BLEmail start Initializing BLEmail...
    Oct-29 20:36:45 Starting Plug-In Initializing plugin BLEmail ...
    Oct-29 20:36:45 Starting Plug-In BLEmail loaded in 15084 milliseconds
    Oct-29 20:36:30 Info Plugin BLEmail has connected. IP:127.0.0.1:62283
    Oct-29 20:36:30 Warning I/O interface BLEmail is down, executable is not running, restarting ...
    Oct-29 20:36:04 Info Plugin BLEmail with instance: has disconnected
    Oct-29 20:36:02 Starting Plug-In Plugin BLEmail started successfully in 2055 milliseconds
    Oct-29 20:36:02 BLEmail start BLEmail plugin has been initialized
    Oct-29 20:36:00 BLEmail start BLEmail version is: 2.0.10.0
    Oct-29 20:36:00 BLEmail start Initializing BLEmail...
    Oct-29 20:36:00 Starting Plug-In Initializing plugin BLEmail ...
    Oct-29 20:36:00 Starting Plug-In BLEmail loaded in 15036 milliseconds
    Oct-29 20:35:45 Info Plugin BLEmail has connected. IP:127.0.0.1:62212
    Oct-29 20:35:45 Warning I/O interface BLEmail is down, executable is not running, restarting ...
    Oct-29 20:35:18 Info Plugin BLEmail with instance: has disconnected
    Oct-29 20:35:17 Starting Plug-In Plugin BLEmail started successfully in 2047 milliseconds
    Oct-29 20:35:17 BLEmail start BLEmail plugin has been initialized
    Oct-29 20:35:15 BLEmail start BLEmail version is: 2.0.10.0
    Oct-29 20:35:15 BLEmail start Initializing BLEmail...
    Oct-29 20:35:15 Starting Plug-In Initializing plugin BLEmail ...
    Oct-29 20:35:14 Starting Plug-In BLEmail loaded in 15087 milliseconds
    Oct-29 20:34:59 Info Plugin BLEmail has connected. IP:127.0.0.1:62177
    Oct-29 20:34:59 Warning I/O interface BLEmail is down, executable is not running, restarting ...
    Oct-29 20:34:33 Info Plugin BLEmail with instance: has disconnected
    Oct-29 20:34:31 Starting Plug-In Plugin BLEmail started successfully in 2075 milliseconds
    Oct-29 20:34:31 BLEmail start BLEmail plugin has been initialized
    Oct-29 20:34:29 BLEmail start BLEmail version is: 2.0.10.0
    Oct-29 20:34:29 BLEmail start Initializing BLEmail...
    Oct-29 20:34:29 Starting Plug-In Initializing plugin BLEmail ...
    Oct-29 20:34:29 Starting Plug-In BLEmail loaded in 15087 milliseconds
    Oct-29 20:34:14 Info Plugin BLEmail has connected. IP:127.0.0.1:62136
    Oct-29 20:34:14 Warning I/O interface BLEmail is down, executable is not running, restarting ...
    Oct-29 20:33:47 Info Plugin BLEmail with instance: has disconnected
    Oct-29 20:33:46 Starting Plug-In Plugin BLEmail started successfully in 2057 milliseconds
    Oct-29 20:33:46 BLEmail start BLEmail plugin has been initialized
    Oct-29 20:33:44 BLEmail start BLEmail version is: 2.0.10.0
    Oct-29 20:33:44 BLEmail start Initializing BLEmail...
    Oct-29 20:33:44 Starting Plug-In Initializing plugin BLEmail ...
    Oct-29 20:33:43 Starting Plug-In BLEmail loaded in 15099 milliseconds
    Oct-29 20:33:28 Info Plugin BLEmail has connected. IP:127.0.0.1:62094
    Oct-29 20:33:28 Warning I/O interface BLEmail is down, executable is not running, restarting ...
    Oct-29 20:33:02 Info Plugin BLEmail with instance: has disconnected
    Oct-29 20:33:00 Starting Plug-In Plugin BLEmail started successfully in 2062 milliseconds
    Oct-29 20:33:00 BLEmail start BLEmail plugin has been initialized
    Oct-29 20:32:58 BLEmail start BLEmail version is: 2.0.10.0
    Oct-29 20:32:58 BLEmail start Initializing BLEmail...
    Oct-29 20:32:58 Starting Plug-In Initializing plugin BLEmail ...
    Oct-29 20:32:58 Starting Plug-In BLEmail loaded in 15051 milliseconds
    Oct-29 20:32:43 Info Plugin BLEmail has connected. IP:127.0.0.1:62049
    Oct-29 20:32:43 Warning I/O interface BLEmail is down, executable is not running, restarting ...
    Oct-29 20:32:16 Info Plugin BLEmail with instance: has disconnected
    Oct-29 20:32:15 Starting Plug-In Plugin BLEmail started successfully in 2061 milliseconds
    Oct-29 20:32:15 BLEmail start BLEmail plugin has been initialized
    Oct-29 20:32:13 BLEmail start BLEmail version is: 2.0.10.0
    Oct-29 20:32:13 BLEmail start Initializing BLEmail...
    Oct-29 20:32:13 Starting Plug-In Initializing plugin BLEmail ...
    Oct-29 20:32:13 Starting Plug-In BLEmail loaded in 15060 milliseconds
    Oct-29 20:31:58 Info Plugin BLEmail has connected. IP:127.0.0.1:61994
    Oct-29 20:31:57 Warning I/O interface BLEmail is down, executable is not running, restarting ...
    Oct-29 20:31:31 Info Plugin BLEmail with instance: has disconnected
    Oct-29 20:31:30 Plug-In Finished initializing plug-in BLEmail
    Oct-29 20:31:30 Starting Plug-In BLEmail loaded in 2411 milliseconds
    Oct-29 20:31:29 Starting Plug-In Plugin BLEmail started successfully in 2054 milliseconds
    Oct-29 20:31:29 BLEmail start BLEmail plugin has been initialized
    Oct-29 20:31:27 BLEmail start BLEmail version is: 2.0.10.0
    Oct-29 20:31:27 BLEmail start Initializing BLEmail...
    Oct-29 20:31:27 Starting Plug-In Initializing plugin BLEmail ...
    Oct-29 20:31:27 Info Plugin BLEmail has connected. IP:127.0.0.1:61951
    Oct-29 20:30:52 Updater Install/Update of package BLEmail was successful.
    Oct-29 20:30:52 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_BLEmail.exe
    Oct-29 20:30:52 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLEmail\Images\optionsPage.jpg
    Oct-29 20:30:52 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLEmail\Images\maintainEmailAccountsPage.jpg
    Oct-29 20:30:52 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLEmail\Images\webInterface.jpg
    Oct-29 20:30:51 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLEmail\BLEmail_Help.asp
    Oct-29 20:30:51 Updater Installing package BLEmail
    Oct-29 20:30:51 Updater Update hspi_blemail.exe downloaded successfully
    Oct-29 20:30:51 Updater Downloading update: BLEmail
    Oct-29 20:30:06 Info Plugin BLEmail with instance: has disconnected
    Oct-29 20:30:03 Plug-In Shutting down Plug-In: BLEmail
    It did work the other day when I checked it, going back through the log it only went back about 40 hrs, and I did not see where it started puking at.
    So I've enlarged by log storage going forward.
    anyone got any ideas? I would really like to get the plugin working again... it was, and then spontaneously stopped
      I think I have it fixed...but have not had time to go in and configure it and test.
      I finally just went in and uninstalled it, then removed all the files associated with it from the computer.
      then I reinstalled it fresh and it is loading without errors. will see what happens when i configure it for email account.
